Evening all,
Got myself a new frame this week that's got a 50mm chainline (i.e for a triple chainset).
Would it be okay to fit a double chainset with a 48.8mm chainline so I can go 2x10?
In case you're wondering the frame is a Santa Cruz Blur TR (retro 26" build) 😀 Anyone done a 2x10 set up?
Yes, just do it.
As far as I know the chainlines are practically the same, the way its measured is different.
The chainline on a triple is measured from the center of the seattube to the middle ring whereas the chainline on a double is is measured from the center of seat tube to halfway between granny and outer ring (middle ring on a triple)?
