2x on x-caliber 7 2...
[Closed] 2x on x-caliber 7 2021?
2 Users
Is it possible to change over an x-caliber 7 2021 to a 2x10 from 1x10? I'd like to add an extra couple of higher gears as I've probably made an error of judgement in what I actually intend to use the bike for against it's intended purpose!
I've noticed the frame seems to be identical to the 2020 version which was a 2x, there is still an e-type mount for a front derailleur on the frame and the rest of the chain set (Deore 4100) appears to have a 2x10 option compatible with the rest of the setup.
I'm clutching at straws here, the bike specs for the bike say maximum 32T chainset but is this just in a 1x setup?
Any help much appreciated.
Posted : 20/04/2022 2:46 pm
I've just been on to trek online support and they say it's ok so I will give it a go.
Posted : 20/04/2022 2:57 pm
I did exactly this on my Roscoe which is the same frame. Actually selling the bits off if you're looking to buy. Barely been used and a total waste of time on my part as I'm now getting rid of the bike.
Posted : 20/04/2022 3:17 pm
Hi Haggis, that's very useful thank you. Good for parts thanks. Why are you still getting rid of the bike did it not have the desired effect?
Posted : 20/04/2022 3:38 pm
I bought the frame with the intention of just building something cheap for winter training up and down the canal. Next thing I know I've got a 29er and 27.5+ wheelset for it. Not cheap ones either, a 1x drivetrain which morphed into a 2x drivetrain. It was better kitted out than the Roscoe 8 and I had gone too far. My employer started doing C2W so I bought a Marin Bobcat Trail 4 instead and it does everything I want. Job done.
Posted : 20/04/2022 7:30 pm
