Hi,
need a replacement fork which meet these requirements, cant find all 3, they all seem to have a tapered steerer.
does the STW hive mind have any ideas?
I found a Reba like that for my brother on one of the german sites. Can't remember which.
Not sure what they are like as a fork, but something like these:
x fusion trace or slide
Manitou, Marzocchi
I've a Reba 100mm travel with straight steerer and 15mm axle if you're interested?
I've got a suntour fork that meets that spec for sale of you are interested?
It's the one off the voodoo bizango and I'm not looking for a lot for it.
Thanks Boris, that's the fork that has failed on my bike. Want an upgrade really.
Any specific models from janitor and marzocchi? I can't find anything except suntour...
Good luck.... not a chance new I don't think.
Your best bet is to investigate either new end caps for your front wheel or a new front wheel, there's a few relic steerers out there new but I can't see anything that is 15mm. Manitou markhour on crc says qr but has a picture of a 15mm axle.
Second hand will be loads easier, pick up a good set of straight steerer 15mm 120mm Rebas without to much bother. Remember dual air Reba are easily changed to 120 from 80/100 as long as they are a certain model, and the newer solo air ones just need an air spring change so you've just got to find 29 and 15mm really.
Thanks nickdavies. I didn't know they were so easy to change will look at some rebas.
Splashdown are they 29er? How much? Can they be converted to 120mm so the geo is correct?
