29er sizing questio...
[Closed] 29er sizing question
6 Users
 td75
So I got myself a used 2008 Kona Unit 2-9 20" with 100mm Tora forks. Reach wise it feels good, I feel stretched out which is nice. But top tube clearance is nonexistent on stand over. I've looked at the frame size chart for that year and I suppose I could go down a size but then I would have a 120mm + stem on it just to get comfy. On the 20" as it is I have the seat right on the front of the rails to get my position right.
Another option is to put a 450mm rigid fork on the front which would drop the front about two inches giving me some clearance. Or is it best to just get a smaller frame size with a long stem on the front?
Also any ideas if you can get 80mm forks with a A-C measurement of 450mm? My back would appreciate something with a bit of bounce at the front.
Does anyone else ride with no stand over clearance?
Posted : 08/01/2013 3:59 pm
[i]Personally[/i] I would have thought the 18'' would have been a better size.
Counter the shorter TT by using a layback post.
Failing that try to find an 80mm fork.
A 450mm fork I would have thought would have been far too short for the frame.
I caan help you out and take the frame off of you if that helps 😆
Posted : 08/01/2013 4:08 pm
Wrong frame and nothing to do with it being a 29er. Sometimes you just have to accept that the geometry of a certain frame will never fit
Posted : 08/01/2013 4:18 pm
that top tube does look high at the front - try a 26inch front wheel?
Posted : 08/01/2013 4:23 pm
 td75
I was thinking that maybe I should swap the frame out. Which is a shame because I love the sliding dropouts of the unit.
I'll try a 26" at the front, that's a good option for trying out a shorter fork on the front.
Everything else feels great about the length of the frame and a layback seat post would make the saddle sit better.
Posted : 08/01/2013 4:33 pm
asterix - Member
Don't try this 😆
Posted : 08/01/2013 4:39 pm
 td75
I've just tried slipping in a 26" wheel at the front and a short fork with a 29" wheel would give me about 2-3" of toptube clearance.
It's looking like I may swap the frame. Trouble is I really don't like the look of many 29er frames and I'm really not a fan of layback seat posts.
Posted : 08/01/2013 4:48 pm
it was a bit tounge in cheek 😉
Posted : 08/01/2013 4:49 pm
 td75
I was thinking of trying a shorter 29er fork anyway before going to a frame swap. So it gave me some idea as to standover clearance.
Posted : 08/01/2013 4:51 pm
Sounds like the frame is too big for you. As Druidh said above, nothing to do with wheel size.
Posted : 08/01/2013 5:15 pm
 td75
I think I may look at swaping the frame. Loved the feeling of the bigger wheels when I've been out on it.
Posted : 08/01/2013 5:25 pm
Ssssshhhhhhhh things have only just settled down from the last 26 vs 29 bunfight.
Posted : 08/01/2013 5:57 pm
