29er rims for rim b...
[Closed] 29er rims for rim brakes?
4 Users
I need one with 36h drilling - does anything decent exist? I'd get a Notubes rim if I could, but all their current offerings appear to be disc only (as do the majority of other 29er rims on offer). Something reasonably wide but not too heavy would be good - would probably go for something like a Rhyno-Lite if it was possible to get them over here (OK, so I'm not after super light, but then one of those is a lot lighter than the obvious uni-specific alternatives).
Posted : 24/02/2013 2:23 pm
I would be looking at touring or cross rims as I am unsure what other non disk options there are.
Posted : 24/02/2013 3:03 pm
Thanks for the tip - I'd really prefer something a bit wider than that though.
Posted : 24/02/2013 3:51 pm
Get them quick. Salsa are exiting the rim business.
Posted : 24/02/2013 4:00 pm
Thanks for the tip - is that 22.5mm internal between the hooks?
I've also found this as an option:
http://www.spacycles.co.uk/products.php?plid=m2b0s116p1569
Given I'm replacing a tn719 and mostly going to run a not too wide road tyre I suppose I could go for something the same width as that which would give me more options - would be nice to have something which would support a big off-road tyre run at low pressure for occasional use though.
Posted : 24/02/2013 4:25 pm
cant remember bead width - Ive run mine with 2.1" ignitors very happily. Not tried the fatter 2.4's though.
Posted : 24/02/2013 4:32 pm
Edit: don't bother measuring, I found this:
http://www.kstoerz.com/freespoke/rim/231
Posted : 24/02/2013 4:38 pm
