29er Lefty Max 140m...
[Closed] 29er Lefty Max 140mm conversion any DIY links
3 Users
want a link to instructions to DIY the spacer to reduce the travel for a 29er conversion
any comments from those who have done it appreciated
Posted : 30/01/2011 10:14 am
absolute piece of pish. There are some instructions on mtbr somewhere, will have a search for you, but it really is simple. Do you have the spacers already? If so, all you need is a small allen wrench and a shimano BB tool, and about 2 minutes. Happy to talk you through it if necessary.
Posted : 30/01/2011 10:17 am
I want to manufacture the spacer (to the right size)
fitting is easy as I need to replace the spring anyway
Posted : 30/01/2011 10:25 am
Sorry to hijack thread, but what's the deal with the conversion? Are you seeing converting a standard 140mm lefty for 29er duties is easy? How much travel are you left with once done? Would it work on a tapered headset?
Posted : 30/01/2011 10:58 am
It's dead easy. You generally lose 30mm of travel (you can risk it with 20mm depending on the tyre, but most go with 30mm). Tapered head tube (I guess that's what you mean?) should be fine...just use the Project 321 adapter & a reducing headset for the bottom race, regular for top. You need to make sure your head tube isn't too tall though...P321 do two different adapters depending on the head tube length.
big_n_daft...can't help on making your own spacers. Not sure I'd risk it personally, but good luck 🙂
Posted : 30/01/2011 11:19 am
spacer is alledged simple, it's the dimensions etc I need
Posted : 30/01/2011 10:05 pm
Thanks Pedalhead, it does sound straight forward and the 110mm I'd have left would be perfect - no joke intended :).
Posted : 31/01/2011 8:35 am
