29er gear ratios 2x...
[Closed] 29er gear ratios 2x10
8 Users
I bought a 29er in the dark last night (one of my better ideas). i got a few quid off ad the front mech was very stiff which i put down to it being sat a while and gammy cables.
this mornjng, leaving forvwork i clicked that the front rings are 22 and 44. is this usual as it seems a little much to ask the mech and chain to me?
what ratios do the fine people of single track reccomend for a 29er newbie? using it for xc racing but im not yet a strong climber so would pike the gears to help me there.
cheers!
Posted : 12/11/2013 9:02 am
24/36 would be a reasonable compromise.
Posted : 12/11/2013 9:34 am
What he said. 22/44 is a very big jump for a double.
Posted : 12/11/2013 9:36 am
22-44 - I'm pretty sure won't work. A double mech has a 14T capacity as far as I'm aware, a triple of course will take that difference but only with something in between. I can't see how you'd get it to jump 22T in one shift with any reproducibility / durability, sounds like a chain waiting to snap for me.
On a 29er, I'd go straight for a double chainset and mech, do it right first time and go for probably 24/36. Or, you could stay with a triple set up but leave the outer unused (or put a bash on to stop you losing the chain over the top) and then even go 22/32 or 22/34.
Posted : 12/11/2013 9:38 am
Dont see why u'd go for 24/36 this is only 12T
Sram do 26/39 or 28/42. This is 13T or 14T difference.
why cant they do 26/40 as this would seem to make alot of sense.
I've got a 28/42 on my 29er but I have fast tyre and only tend to use it in summer.
Posted : 12/11/2013 9:43 am
Because 36-11 is a high enough gear for XC racing and would mean that you don't have to front shift as often
Posted : 12/11/2013 9:55 am
Yes, you could get 24/38 on shimano too.
My reasoning is that on a 36T front and a 29er, I found i was staying in the outer for most riding and used the inner for steep climbs and as a bailout. 38 would be just that bit taller and would see me changing the front more often. I never seem to run out of gear at the top end so 36-11 vs 38-11 is no benefit.
FWIW, I have 26/38 on my 26er but the difference in wheel size means they are actually pretty similar. And in any case my 29er is a single front set up now (30, halfway between 24 and 36, although did have a 32T for some time and that was OK too)
Posted : 12/11/2013 9:57 am
 st
My 29" came with a 24/38 double and while I was sceptical I stuck with it and it's been great, I find myself using the outer ring almost excluisively and it's been pretty good as it seems to help me to keep a slightly faster pace than I might have done before.
I've got to the point where I'm questioning keeping the granny ring although if I did go to a single ring set up I guess I'd drop to a 36t ring.
Coincidentally I've got a double ring set up taken of some 2 rind Deore cranks that are unused and available if you;re looking to change. Email in profile if you're interested and I'll check the rind sizes.
Posted : 12/11/2013 10:15 am
38/22 on Trance and Tallboy (i specced this)did try a few weeks only using big ring.... worked ok even on gnarly Manx climbs but chain and cassette don't last long ( we were beasting it a bit) so back to both rings and this ratio is great on our varied terrain
Posted : 12/11/2013 10:41 am
