29er Frames for 120...
[Closed] 29er Frames for 120mm forks? Current geometry?
25 Users
So Ive decided that when I get back in September Im going to strip the Parkwood and sell the frame as Im just not liking it, I feel on the bike instead of in the bike if that makes sense.
So Im looking to replace it with a current geometry 29er frame suitable for 120mm forks.
Budget will be upto £400 so what sort of thing should i be looking at?
It will be sued for a split between commuting and general riding about the area.
Posted : 12/05/2016 9:34 am
This assumes you want another HT:
Whyte 2016 (geo change for this years bikes) 5/629 2nd hand, with a proper sized TT/reach for tall ppl, t'is what I'm looking for. £400 should easily get you a frame 2nd hand (only sold as complete bikes) but finding someone to split one seems an issue.
Nukeproof's 290 HT, is a viable option f/o but the 120mm fork might be a bit short.
Posted : 12/05/2016 11:19 am
Genuine question.
Do you simply enjoy the buying of bikes and parts more than riding them?
You seem to be addicted
Posted : 12/05/2016 11:35 am
 mboy
Stanton Sherpa and Cotic Solaris are both worthy shouts, but you'll have to up your budget slightly.
Does seem there's a glut of 29er HT's all designed around 140mm travel forks now with incredibly burly tube profiles, and there's still a number of nice frames designed around a 100mm fork with racier angles and shorter reaches. There's almost nothing I can find with what most people now refer to as "trail" geometry (for want of a better term for it) with slacker head angles, longer reaches etc. But designed around a mid travel fork (ie. 120mm or so) and not stupidly burly...
It's why, as z1ppy suggests above, I bought a Whyte 629 and upgraded it, couldn't find anything else with the correct combination of geometry and weight that I wanted. There's a definite market out there for someone to bring out a sub £500 29er frame only, sub 2kg frame weight, designed around a 120mm fork with short(ish) stays, slack(ish) head angle, but with proper reach figures to allow the use of 50mm stems and seat tubes short enough (with internal routing) to take advantage of the new breed of 150mm drop posts on the market. Stanton and Cotic come admirably close, but IMO the BB height on both is 10-15mm taller than ideal and being steel they're giving away 1lb or so against an equivalent ally frame.
FWIW my heavily upgraded Whyte 629 is damned good. The only thing I'd have preferred is to be able to buy it as a frame only. Well that and 5-10mm off the chainstays and stealth dropper routing would be rather nice too!
Posted : 12/05/2016 11:43 am
Scandal..... Why not, it's a hobby I enjoy. They do get ridden more than it seems.
Z1ppy yep after a haedtail, I have a stumpy 29er full suss already.
Looking to transfer the kit off the parkwood frame.
Park wood frame is a bit to short of I'm honest.
I like the look of the Orange Clockwork 29er but it's max fork travel is 100mm.
Mboy... I looked at the Sherpa but is doesn't seem to have much more reach than my parkwood frame ?
Posted : 12/05/2016 11:52 am
When has anyone seriously taken any notice of the frame max fork travel?
Run a touch more sag
Run an offset headset
Reduce the fork travel
Care less
Posted : 12/05/2016 11:59 am
Or just run a 100mm fork with the orange. BTR recommend that with a 29er Ranger and they probably ride a damn sight harder than you do - no offence intended.
Posted : 12/05/2016 12:03 pm
I'd just buy a bigger Parkwood frame
Posted : 12/05/2016 12:04 pm
But I already have a brand new 120mm fork.
Already have the largest parkwood frame.
In the STW spirit of recommend what you've got, I'm running a second hand Santa Cruz Highball which was in your price range, and have had no issues running it at both 100 & 120mm travel. I think its an awesome frame - Stiff, light, racey when it needs to be...
Posted : 12/05/2016 12:11 pm
It's not exactly hard to change fork travel.
I think the Last Fast Forward frames can be run 120mm and are pretty close to your budget. Back wheel will need dishing though.
Posted : 12/05/2016 12:27 pm
As much as I love the progressive nature of the Last FF I'm not sure could be called "current geometry", futuristic maybe.
Posted : 12/05/2016 1:09 pm
Not too keen on that to be honest, it looks to slack at the front.
Quite like the Genesis High Latitude 29 frame too
Posted : 12/05/2016 1:16 pm
I would have said Solaris but as mentioned by mboy, you'd need to up the budget a bit.
I've just upped the travel on the forks on my (Mk1) from 100mm to 120mm. Much prefer the way it rides now, although the BB is a tad higher than ideal if being picky (although it has been useful when riding through some rutted fields recently) and I may be only noticing due to the lower bb on my other (fat)bike.
Posted : 12/05/2016 1:21 pm
I have a high latitude built up with 120mm forks. Only been out properly on it a handful of times as only recently finished it but it seems to be ideal for what I'm looking for which sounds to be similar to yourself.
Posted : 12/05/2016 1:25 pm
Post some pics up please !!
Posted : 12/05/2016 1:30 pm
Not sure if that was a general request or for Gaz6r4 but just in case it was the former:
Although the grips are different as of today!
Posted : 12/05/2016 1:39 pm
I've got a 2015 Genesis High Latitude frame BNIB, never got round to building it up.
19" (L) in electric lime green I could let go of if your interested OP?
Posted : 12/05/2016 1:51 pm
It was a general request to be honest.
What size is that Solaris normal man ?
Size wise the Solaris sounds ideal as its 2cm longer in both reach and top tube compared to the parkwood which would be ideal.
Posted : 12/05/2016 1:52 pm
Mine is a medium.
Posted : 12/05/2016 1:53 pm
How much fenred ?
Posted : 12/05/2016 1:54 pm
I'll drop you a mail and we can talk. 😉
Posted : 12/05/2016 2:06 pm
Posted : 12/05/2016 2:15 pm
[url= http://www.bansheebikes.com/bikes/paradox/ ]Banshee paradox?[/url]
Bit pricey but seen some go second hand for reasonable money. 120mm fork, 29er frame, geo looks like what you are after and great reviews.
[url= http://interbike.mtbr.com/banshee-bikes-interbike-2010-virtual-tradeshow-booth/banshee-paradox-interbikephoto ]Photo here[/url]
Posted : 12/05/2016 2:24 pm
Zealous Division Mk1 in XL may be an alternative.
Not sure what it would be like for commuting though, guess it depends on your commute.
Posted : 12/05/2016 2:27 pm
What size is that genesis ?^^^
Posted : 12/05/2016 2:30 pm
How tall are you Renton that the L parkwood is too high.
Posted : 12/05/2016 2:33 pm
Duckman.... It's not to high, it's to short to be honest and I can't get comfy over the cranks.
I've got a lay back post already and still keep shuffling rearward on it.
Posted : 12/05/2016 2:40 pm
Large. Can pick up a HL frame for next to nothing as well.
Posted : 12/05/2016 3:38 pm
Gaz..... I've just realised where your picture was taken. Top of the red at moray monster trails.
Are you local then ? I'm based in Elgin
Where did you get it from by the way as all the cheap ones seem sold out everywhere.
Posted : 12/05/2016 3:55 pm
What size stem are you using Renton?
Saw you built the parkwood after the rear disc trouble, then said that you were liking it more and more that you used it, and now you wanna swap it again. You sure 2cm top tube is going to make that much difference to your enjoyment? Maybe you should try something else, different wheel size or something.
Posted : 12/05/2016 3:57 pm
Coomber.... When I started riding the Parkwood I hadn't rode anything for over 5 months.
At first it felt great but the more I've rode it over the past week the more I've realised its to short. In fact the reach is the shortest of any bike I've ever rode.
I've got an 80mm stem on it.
Posted : 12/05/2016 4:01 pm
It's not overly long I will give you that. Don't want a longer stem than that either, unless it is more commute than off road then it wouldnt bother me.
I'd ditch 29 and go for something long like a bird zero. But that doesn't help much.
Or genesis/whyte/solaris will pop up eventually for your price bracket.
You may also consider the vitus which is 30 odd mm longer in reach, although you will need a new rear wheel. I'm quite tempted but dont know much about them.
http://www.chainreactioncycles.com/vitus-bikes-sentier-29-hardtail-frame-2016/rp-prod138756
Posted : 12/05/2016 4:08 pm
If you want to feel 'in' rather than 'on' the bike you want a low BB and a long reach. Do you shuffle back on the Parkwood because you find the seat tube too steep or because the bars aren't far enough away?
Posted : 12/05/2016 4:13 pm
I have a 19 inch high latitude frame that I could be tempted to sell stevie
[url= https://farm1.staticflickr.com/462/20028135782_d7d2fc4e55_k.jp g" target="_blank">https://farm1.staticflickr.com/462/20028135782_d7d2fc4e55_k.jp g"/> [/img][/url][url= https://flic.kr/p/wvPqZU ]20150725_175001[/url] by [url= https://www.flickr.com/photos/35180712@N03/ ]simon gardiner[/url], on Flickr
Posted : 12/05/2016 4:28 pm
Aye that's exactly where it is.
I bought it second hand from the classifieds. I am based in Elgin too.
Posted : 12/05/2016 4:43 pm
I might have to pop round and throw a leg over it one day when I get mate of that would be ok.
How much you looking for ssimon.
Posted : 12/05/2016 5:19 pm
I have that very Vitus frame! I bought the bike. I am on a large and am 6" 2" with a 34" inside leg.
Posted : 12/05/2016 5:26 pm
Chief.....
The problem with the Parkwood is that I'm trying to shuffle back behind the bottom bracket I think.
I know its probably old fashioned but I like my knee to bee sort of over the pedal spindle. And great variation gives me a fair bit of leg pain and I feel as though I don't get full power through the cranks.
I had the same issues with the 650b trance I had.
Posted : 12/05/2016 5:36 pm
parkwood geometry is a bit of a con. It's the same as an inbred but table is with a longer fork so it looks slacker.
agree i'd like a 120mm 'trail' hardtail. not a big burly trail bike but an XC+ type bike. I think the whyte is about the only thing i've seen.
Posted : 12/05/2016 5:38 pm
 mboy
VERY much the feeling I get on this...
[img] ?oh=8eb9259696ff911d200f2ae92dd65a8a&oe=57AA82B1[/img]
It's an inconvenient and somewhat expensive way to get exactly what you want, buying a bike then upgrading everything on it, but I knew from the geometry it was the closest to what I wanted (which was the limited edition Whyte 929 from a few years ago in truth) so went for it... The Whyte geo chart is a little conservative too to be fair, as with a 120mm fork on I've measured my medium sized bike at 67HA, 1160mm wheelbase, 308mm BB height (with 2.25" tyres) and the reach/stack/TT lengths are all perfect for me running a 55mm stem and a low rise bar (I'm 5ft10 FWIW). It corners like its on rails, and at under 26lb inc Reverb and pedals its no slouch when you stamp on the gas!
Posted : 12/05/2016 5:46 pm
I got a 25mm layback post, it makes all the difference
Posted : 12/05/2016 5:53 pm
I also have a L Parkwood and in comparison with my XL Smuggler it is pretty short, but I quite like that for what I use it for, it turns really nicely for a wagon wheeler. If I was doing xc races I'd want something longer.
Posted : 12/05/2016 5:54 pm
Mboy are you saying that you shuffle back all the time on the whyte or do you fit in it ??
What size is it BTW. I think I would be after a large ? EDIT doh just read its a medium.
Posted : 12/05/2016 6:09 pm
Trek Superfly is pretty good geo on the trail, but only 100mm forks. Nice long ett, plenty of standover and takes 2 bottles (essential for long tides for me).
Posted : 12/05/2016 6:36 pm
Ssimon.... How much for the genesis frame ?
Posted : 12/05/2016 9:23 pm
Aye no worries, my email is in my profile.
Posted : 12/05/2016 9:30 pm
Pinnacle Ramin?
Posted : 12/05/2016 9:45 pm
 mboy
Fit in it nicely. It's got a nice low BB, long front centre, slack HA, very much feel in the bike not on it.
IMO On One missed a trick with that Parkwood, cos the price is right, the weight is bang on, but the geometry is somewhat behind the times... Seat angle is too slack, head angle not slack enough, reach figures are at least 25mm too short size for size, and the head tubes could be shorter. Oh and the BB whilst not lofty could be lower.
Posted : 12/05/2016 9:58 pm
The 650b parkwood geometry is worse, about 20m less real than the 29r
Posted : 13/05/2016 5:44 am
*less reach* even.
I need more coffee
Posted : 13/05/2016 6:15 am
Don't understand it to be honest. On one are normally pretty good geometry wise but this seems a bit strange.
Posted : 13/05/2016 7:02 am
Not the cheapest way to do it but I had Nicolai make me an Argon custom. 470mm reach with a shorter back end. Mine is an XC race bike but they will tailor their bikes however you want for a cost.
Posted : 13/05/2016 7:13 am
renton - Don't understand it to be honest. On one are normally pretty good geometry wise but this seems a bit strange.
Things change, OO didn't that's why.
Posted : 13/05/2016 7:59 am
I've nothing to add, apart from; thread by Renton, yey!
Posted : 13/05/2016 8:05 am
:mrgreen:
Posted : 13/05/2016 8:27 am
Hmmm, not convinced about that, latest On One email introducing the DeeDar as "long low and slack", err sorry but that's not long by any stretch of the imagination (or even reasonably long)
Posted : 16/05/2016 1:47 pm
^ Surely the 'DeeDar' geo is wrong? Surely?!? 😯
Posted : 16/05/2016 5:21 pm
Nukeproof Scout? It's built for 130mm (if there's such a thing as a EC56 headset, that'd deal with that) and you'd probably want to go up a size as it's short of reach... But it's good. Even with a shorter fork it'll still be slacker than a lot of the competition. It's also stiff as ****, I couldn't live with that personally but I liked it otherwise.
Posted : 16/05/2016 6:16 pm
Had a similar issue with my fireline - great bike but way shorter than advertised so reach is way down. So that is for sale! Ended up going for the Cotic Solaris mk2 in XL to get the reach I like. Building up now but looks great in gunmetal grey! I tried the Scout and it is fun but you would not want to ride it all day - it really is stiff.
Posted : 16/05/2016 11:32 pm
Crashrash, what size is your Fireline and how does it differ to O-O's shonky geo charts? And obviously, how much are you after?
Posted : 17/05/2016 11:52 am
