The forum search on 29" or 29" tyre did not work so I giving plan B a go and asking all the 29" loons on here what they think is the best 29" front tyre, happy to go UST or the normal tube way.
The tyre has to be light in weight and grippy, I'm less worried by the cost and wear factor as the bike is more for big multiday rides so its not going to be out every weekend.
Heres hoping the ST 29" riders can get me on the road by this weekend, thnx Paul B
I use Maxxis Ardents, but the new Schwalbe Nobby Nic looks like its going to be good.
Paul - I did the TransPortugal on Hutchy Pythons. Not very light but pretty reliable. My current favourite is the Bonty 29-3. Light, reasonable traction in all weather conditions (excluding heavy rain) and they roll well. They also slip onto my Mavic rims very easily, unlike most tyres.
Tyres are a preference thing so expect to get 100 different answers! Also, where do you intend doing your events? This question is probably more important in determining your tyre choice.
And my next point is that if you can run tubeless!
Have been running a WTB Prowler for, well ages, on both 29ers and its great.
Racing Ralph out front in summer. Just tried Maxxis Aspen out back and impressed so far.
Edit - ignore the bit about rear tyre!
Another vote for the bonty 29-3, great summer tyre.
Thanks for all your replies. If I could get a 29" Nobby Nic I would, we are always behind the Americans on tyres, the American forums also reckon there is a 29" Mountain King ready to go. I'm hoping to get a tyre thats under 650grms as my legs need all the help they can get.
Another vote for the Ardent but they are over the 700g mark. If you are after light and grippy (in dry conditions) it's pretty hard to go past the racing ralph. Don't always play well tubeless though.
Any suggestions on what equates to a 26" Conti Vert which I like? How's the Race King? Any good as an all rounder?
Mountain king 2.4 if it is soggy, racing ralph 2.4 if it isn't. Both tubeless, and if I'm honest I don't like either with tubes as you seem to need to run high pressures to stop pinch flats. If you want to run tubes try the Ardent. The bonty ACX is a good all round tyre for either end.
But then it depends on whether you have suspension, how heavy you are, what your terrain is like and how you ride it.....
Clubber - Maxxis ignitor looks the closest to a vertical that I have seen.
Singlespeed.nl for the Nobby Nic, got one a couple of weeks ago and swapped out the previous Racing Ralph for this up front.
I had no issues with the Ralph, but fancied a NIC as I run a Nic/Ralph setup on my 26er, I found the Nic a bit slower on the first few rides but starting to appreciate it now, particularly the extra grip when braking on sketchy descents.
Shak47 big thanks for Nl link
Shackleton, its a going on Reba forks and an old protype Scandel frame with 29" up front and 26" on the rear, its one big experiment and no matter how hard I try I cannot get my lard arse weight under 200lbs and you can add another 15lbs for kit and camelback.
bontrager ACX in the slop
or racing ralph 3 seasons.
ignitor and vert pro although having similar shape knobs don't ride very similar due to the much lower profile of the ignitor.
The new Rocket Ron 29er, lighter and grippier than a Ralph, quicker than a Nic.
bontrager 29.3 2.3 front 2.0 rear combo is the best I've found so far for peak district rocky bits/cannock kitty litter/hanchurch sloppy ploppy mud.
Wasn't that impressed with ardents,aspens are good, love schwalbe tyres but ralphs and rons can have interesting latex spewing moments when playing with stans rims after a while as the bead can stretch a bit and let go quite dramatically. The furious freds were epically quick but definitely not a front tyre!!
