29+ frame with 135m...
[Closed] 29+ frame with 135mm rear end?
14 Users
Got an old on one inbred with krampus fork at the moment. I’ve gone 29+ at the front and keen to go fatter at the back. Anyone know where I can get hold of an old 135mm 29er frame that will take a fatter 29 tyre. Ideally 3 inch but even just comfortably fitting 2.4 would be fine
Posted : 15/06/2020 12:37 pm
Singular Rooster is 135mm at the back and takes a 3 inch tyre, if you can find one!
Posted : 15/06/2020 12:40 pm
 Spin
Current Genesis longitude will take 29x2.4 and I think, although I'm not sure, some older versions might take fatter again.
Posted : 15/06/2020 12:42 pm
Got a Large yellow Singular Rooster Frame & Fork I've been thinking of selling. Let me know if interested.
Posted : 15/06/2020 12:43 pm
The original Krampus was 135mm at the back.
Posted : 15/06/2020 12:54 pm
So will the new one too (I think you may have to use in insert or chip of some sort though)
Posted : 15/06/2020 12:59 pm
Sent you a DM @zigzag69
Posted : 15/06/2020 5:48 pm
Singular swift MK1 with a 2.4 ardent up the back.
https://flic.kr/p/suU8hD
On one reckon the scandal with take 2.6iirc
Posted : 15/06/2020 6:15 pm
Velo Orange Piolet of Surly ECR?
ECR needs some canny adapters but lets in 3 in tyre at the back, Piolet 2.4 at the back, both 3 at the front. Both a bit touring oriented though.
Should admit I've not seen either in the flesh but both look the business on paper (or screen)
https://velo-orange.com/products/vo-piolet-frameset
https://surlybikes.com/bikes/ecr
Posted : 15/06/2020 9:29 pm
Probably depends on the specific tyre, the Goma 2.4 fits with acres of space, 2.6 might but could be a bit tight if it was a big 2.6 or rim.
Posted : 15/06/2020 9:46 pm
Anyway, scratch that the scandal has a 148mm rear ☹️
Posted : 15/06/2020 10:25 pm
MK2 Singular Swift will take Plus rear. Not sure about 3" on a 50mm rim, but certainly 2.8 on a 40.
Just sold mine.
Posted : 15/06/2020 11:11 pm
Size? Small Longitude Mk1 (29+) on fb at the minute
Posted : 16/06/2020 3:31 am
Stooge?
Posted : 16/06/2020 8:48 am
Older Jones plus has 135 rear, but then comes with the odd 142 front..
Posted : 16/06/2020 9:22 am
More recent Kona Unit frames have decent rear clearance, and they have sliding swappable dropouts. I've got a 2018 frame with QR dropouts and a krampus fork, it happily takes 2.6 in the rear on a 35mm rim.
Posted : 16/06/2020 10:00 am
