29 forks non boost ...
[Closed] 29 forks non boost what are my options ?
7 Users
Afternoon
So I've a 29 frame and wheels but they are a non boost pair not wanting to go down the dishing route what are my options ?
There's some Epixon on fleabay for £200 and some X-Fusion slide for £320 is there any others ?
Posted : 27/10/2020 2:54 pm
There should* be plenty of options on forks but the easiest is a cheap set of adapters (2x5mm spacer and 5mm disc spacer) no need to dish if you don't want to (though it's not as scary as it sounds)
*plenty being more than 3 or 4 but a lot will be budget ones.
Posted : 27/10/2020 2:56 pm
You can get boost adapter kits that don't require dishing..
Posted : 27/10/2020 2:57 pm
Aye. It’s a 5 minute job to convert any wheel. Why limit the fork choice or wheel options in the future...? Buy boost!
Posted : 27/10/2020 3:21 pm
If you can't get a boost kit for the front wheel (no dishing really needed if the kit is done properly) then the wheel is probably not worth worrying about.
Buy a boost fork IMO.
Posted : 27/10/2020 4:18 pm
What travel you after? Going to be getting rid of a set of 160 yari in non boost soon. Used but in good condition and serviced fairly recently.
Posted : 27/10/2020 4:21 pm
I'm after a 140mm for my Canfield EPO
Posted : 27/10/2020 5:17 pm
 poah
I just use the cheap adaptors in my boost fork.
Posted : 27/10/2020 5:53 pm
