28t narrow wide rin...
[Closed] 28t narrow wide ring
6 Users
Is there anything out there more towards the Superstar end of the price range as opposed to the Race Face end of the price range?
104bcd.
Posted : 13/06/2016 5:21 pm
You'll not get a 28T in 104.
Mrsstu has one of these which works well.
It's a 28T but bolts to the 64 granny tabs.
http://absoluteblack.cc/xx1-style-shimano.html
Posted : 13/06/2016 5:27 pm
Not available in 104bcd AFAIK, 30T rings are modified to fit as they are the lower limit. 30t oval maybe?
My mistake, by the looks of it the crank is a SRAM one with a removable spider, does that mean you can get those funky direct mount rings?
Posted : 13/06/2016 6:03 pm
Can you get a 30t oval to fit 104bcd?
Posted : 13/06/2016 6:14 pm
You can but I'm not convinced by the whole oval thing, round works for me.
Posted : 13/06/2016 6:38 pm
steve_b77 - Member
Yep, 3 T25's to remove the spider and fit a direct mount ring. Simple and easy.
Posted : 14/06/2016 2:22 am
Yes, the x-sync SRAM rings are what you're after.
Those steel ones are a bargain too. Cheaper than any of the alloy ones I've seen and should resist both wear and impacts much better too.
In answer to some of the earlier questions:
No, oval 30t will not fit on 104BCD, 32t oval is the smallest compatible with 104BCD
30t round is the smallest non-oval that will fit on 104BCD.
Posted : 14/06/2016 8:17 am
Ecky-Thump - Member
Thanks
Posted : 14/06/2016 8:46 am
