Reckon they'll fit?
With 11/8" tyres, that's about 28mm.
I've got some bolt on 120mm spaced large flange ones.
Also got an unused On-One s/s chainset, bars, stem, levers, the lot except cantis.
Posted : 02/09/2012 4:54 pm
Its only 8mm bigger diameter than 700C. So it will probably fit fine, at least without mudguards.
You may need to tweak the brakes a bit, to get the pads lined up with the rim.
Posted : 02/09/2012 6:47 pm
