27.5ing a Prophet h...
[Closed] 27.5ing a Prophet headset help please....
7 Users
So, I've been a right lazy **** since getting the golf gti last year and not ridden for the best part of a year..... 😳
I want to build up the Prophet frame again, I bought a 200x57 shock ages ago for it but I can't remember if it has to go in the xc 69 deg setting, think it does though?
Was also think of trying out a works headset so wondered about going for a 1.5 or 2 deg one?
Anyone still running a Prophet as a 27.5er if so any advice on which to go for?
Forks will be 140mm.
TIA
Posted : 12/08/2016 2:52 pm
I'd have thought you' probably want to compensate for the big wheels by decreasing the travel in order to keep the geometry the same, otherwise it's going to get pretty tall?
Assuming the wheels are 25mm bigger diameter, you' have to knock that much off the fork travel, so ~120mm forks, because the axle needs to be ~12mm higher and the axle to crown also needs to be longer for 650b forks for the same travel.
If the shock ratio is 2.47:1 (140mm and a 57mm shock) then a similar decrease in travel would be a 190 x 50mm shock. You might get away with a 200mm shock in the FR setting, but it would feel like the XC setting in 26" wheels.
I've no idea if that fits, but if it does then it'll handle better than trying to cram 140mm of travel and big wheels into the frame.
Posted : 12/08/2016 3:52 pm
I can't remember, there was an old thread about this I'll see if I can find it. Pretty sure the standard shock is 200x50 and fitting a 57 stroke gives the frame clearance needed for the bigger wheel.
Posted : 12/08/2016 4:23 pm
It would have to be the other way around, as I'm pretty sure the prophet had a 57mm shock as standard an a 50mm would stop it hitting the seatube at full compression with a big wheel.
Posted : 12/08/2016 4:31 pm
Prophet is 200 x 50 stock. 57 would have you buzzing the seat tube for sure. I reckon it will be stock shock in XC position or something with same i2i but shorter stroke.
Posted : 12/08/2016 5:01 pm
Think I'm right guys but I've looked at my 47 pages of favourites and can't find the old thread which is a pisser, so I'll have to trawl through my history, joy of joys....! But.... if anyone that's done the mod can confirm either way that would be great and save me 3 hours of my life cheers.
Oh and also the headset thing too 🙂
Posted : 12/08/2016 5:07 pm
Just type:
prophet 650b site:singletrackworld.com
or,
prophet 27.5 site:singletrackworld.com
into Google.
Posted : 12/08/2016 8:21 pm
Put a -2 headset in the bike. It'll drop the BB a bit as well as slackening the HA.
Don't forget you can always get a tuning company to adjust the stroke, length, etc if you need to.
Try both settings and see which works.
Posted : 12/08/2016 9:12 pm
Fit a 190mm x 50mm shock to keep it low enough to feel normal. The Prophet SL came as standard with a 190mm shock and everyone complained about the low BB and pedal strikes, so with 27b wheels it should be OK. Prolly need the XC setting though for bigger wheels.
Posted : 12/08/2016 9:50 pm
I run a prophet 26in, 190x50 shock in xc setting ( to make up the 10mm on stock 200x50,equivalent to fr setting) i buzz the seat tube with tall tyres. I doubt this setup would work with 650b.you will smack the seat tube good and proper.
Why so keen for 650b? Why not just stay 26?
Posted : 12/08/2016 10:16 pm
Great frames by the way, absolutely love it.
Posted : 12/08/2016 10:17 pm
Cheers torsoinalake, I keep forgetting that it's been mentioned on here before....
I'll have a butchers later.
Because I can! Well when I find the chuffing link and info, I can 🙂
If I don't like it I'll change it back, just wanted a cheap way of trying a 27.5er.
Oh and I looked on Works site and they're not showing a headset for the Prophet frame, I'm sure they used to have so I've emailed them.
Posted : 13/08/2016 11:52 am
D'oh! Of course, you'd need a longer shock with 50mm stroke... 😳
Posted : 13/08/2016 2:50 pm
Something I've done in the past with 200x50mm shock in the FR setting. It slackens the angles(I much prefer chopper-style geo) and drops the bb which is more important when fitting larger wheels.
[img] https://lh3.googleusercontent.com/zMegSdEz7eCzkEOayP0xn67PZfesBNMbvXMh5LbS2GWD4WemUGC9zesZmC65TQFMD109mDtSyaVCHkPoxPKt-Jj9GQleRnVJfzi0o6hbBcaSqT2DiImQ32yHtCdhi-5BGag-C0WZiIwcAdiNx5BnzWHuISWFkMl2aVisjqEAkmdDdy00GKJotjcQ-3IewujCxH9gQ754cau_UMqfIBHWe16U23mjmOeCw-gMwDbNlyh6B1UIfOYs-9MrJ0uxxZBlT3EbOVPqmtsOS0Qlftz7NEY7uTM64Ydk0tzk1CE36DckTUOSoK17hIXQd6Xb1D86J5iuRaisvVDSwTEGgmiEO8m0eE0XzkO_IAY-EKoGMoRTDMUDbFyL3rFi8wBzku3GC-2EDPcm3QhQTba4I70XFIk1Ycp-1EIcA-GmqvXB80KKDS_WQkoKxpYBMsWgvvtfJMxasdcUDKK_1N40-fxB-FnG7wNBrS5l3EqrQtSqp8Qu2dJIP1KF4T2_hY6eXUCPd1TdbxWA_zdlO9LYjpeEwaPc0usH9EskmjfmG4YkPjsNHbUyI4Llzzu6uo6rspMxct_OkgH3DVSrL0c1RwLfY5OusZ_8RfE=w890-h667-no [/img]
There isn't much clearance with the f.mech and I have a vague recollection that you could only fit a certain mech to make it work? Or perhaps chop off some of it??
[img] https://lh3.googleusercontent.com/YBF9Cv5lNOBHQnLUSrJ8KmzqqR38ZszworGxUvu1OAvuz9_bqFOPB0j_u21EEcqAWSuaXcp3PuDfASVrQzYYAp0zkYaitEcj9FfXa5vJw3ZHn6ejBkaHejAIf7JtvGjoW-W7OwKEOUpEpqS-vtuhHzjY_wjefR2PnmGamdQQR-985CMt7seETXZFTBQK-i1MV4vhoQt6mNOtjyRnTPJvtrLipeFNj26KENHySyjCNop2HoEwoaooZHoVyckgakRO9DTxLziQKemDaFupCW3AUN50IRuk7YeaGir1a7dDmi4ZrE1yow1xKmc4vZh5OFTqxVx_lCisdPvhLTUxAzCVlxQaiOiAvR3Vr9NOJ0FEaUeZIxDudbZwtq2p6IuyUJSAOpKZi_RZj1KOxzbWvQ0nbd0QTPJMgGrsV7TLC626h-Gfl6S2wmPS4ZVelHjntpA0PVKQKdBeFrkyzMKhqIop-01B6ImGjnX0VFbf0Tj7ssLcMqCuDjSQYcGkr3Y5P5Rvv6Ju1qVnoxL-WJ24vT74OOA9vttiTb1iCDxWHmSejm5TJDint2N6GV1EOgdx1pzQX3qoZ5eAE2qopyeHsJk0D1nB8ICNAwY=w890-h667-no [/img]
[img] https://lh3.googleusercontent.com/EjlWHHzRTvyDZNL3Mi47GEdWwnV0AjnKEZg7_Rr64GyEHIK3FJbmO8zhh5EPlA2YL3ETjgReC9AwUlkFUGOZYwqu_doaoc0vBRe4CGIvJFu_F7xOD5JpsHwO6WkjTatoFaMZG6gGNpLa853_cFcDjmsCjtb7YeEqFxVExJ1OzoyCZzje25YXDh3A05oREamQmNJI4Unail7qbZjm0xynJBlQyNel3nDbhw3eHtfCHrVrPYLh0q-8DRTFtvxQ83YI03COCIBLFiwAG7UvYqRwJvHAKqRDJSprA2QJGAiNkqTpzYjTfvfyovcfS6mRYDLAs7aqa_h5gNxfTSB-8v5H4UJ9rFeYdwVE_0dRB2qwak5pZUaVyrISsIB9r1U32auw5kkcUOcEMfJcAlbaZzVExBsNIRfJDX5zIdypVTy-1toMAryCB3x95Ty91L-fIw7_M49fkrUajVXrcyB05vF-hDiSnXINIemhfUgb6e_LkfIFUeVwMOCUzE1x_s3HAcGC5Qz3sWdsl9wZzULIS3B9GbU1Rhsz-tya_cpt3JR6BO0_PhHT7CFoOD0ZD8uE0LT5YkIGxIDaIGGrci8Xs_67l7h6WnDSnHc=w501-h667-no [/img]
Pacenti NeoMoto 2.35 tyres on Halo Vapour rims...and here's a clearance with 26" Floats:
[img] https://lh3.googleusercontent.com/HJIN2Pz8VtBwV_sMQsCL02S0zFFSytzXXD5P6kuCLwa3OxEbJaGFxva-tqTC9tSQXDbasDcjDisYGBynBdkq2Nme01bikOMECHJXHgZ1hiqezSNFMAziU_UCQ_kjwJd5zwxq6YZm72wLj4kUmybGnD0F6nEtQvBIwa9Ml57ftaf5S71J3weXkQaSkBIjrv_xPZ0xQpXmEquR5r3Bzy7dm1Vv6SppPlyhda1sBq1nZDB0i3tqHF8b8fPaLdxBrFvEwCJzMyyFFvHAW2TIBrKnaoPo7GhVouLZVr56LoGTaj5STT3JC9eh0lfO5Z0NMCC0wb6UyBkWGAK9qkJagAIxsRrV-I77aQ6qh0VIzDPEm899bROXIiqi-fjpnK_MhRWnKQKkzsP054nbT7Eqow6lHrgKy0KrnemBBzzbFxLLL281FrJTHcUWGpreR2NUyXplbyu56yeEPyKp6jCUZBvVFkmigsHsfZeYIFfN2iLqm0g9bz4XzjB6GjREx7N4-wco9DZz4BgqryI3BkGSe1ptK7OgZ7bdiumvzxQ16hU8RI31hhaK2K4s74Iq42Me1etIm4ccAeketPlePfIHsIEAob3FgFHOVXo=w501-h667-no [/img]
It was a few years since I've done it but should you have any questions please fire away!
EDIT: stupid stupid google photos, where's Picasa gone? OP, drop me an email and I can send you the pics...
Posted : 13/08/2016 5:29 pm
Emailed you cheers.
Posted : 13/08/2016 6:08 pm
