As I'm behind the times, all my bikes use a 27.2 post. I've got an original GD, a Traildrop and a Sattori/RSP. Quite happy with the pin-on-a-spring method, but it would be nice to drop more than 100mm. Is it possible? Or do I need to revert to the QR lever also for more substantial downhills?
(or buy a new frame?)
Ks lev do a longer drop one. But 100mm drop is lots are you sure you need more?
Presumably, yes, since he has 100mm ones and wants more drop 🙂
Fair enough.
Get a 150mm drop ks lev then
Thomson, 125mm - expensive but good.
If you replace one let me know, I'll have your old one off you 🙂
The LEV is only 100mm in 27.2 size.
Thomson it may be....
