27.5 plus fork
[Closed] 27.5 plus fork
3 Users
 iolo
I am getting dome second hand Ghost Teru ebikes but they have bad forks (Suntour XCR that desperately need a service). I would rather replace with a semi decent fork.
Is there a specific 27.5 plus fork? Or should I get 29 inch specific forks? Would I actually need 27.5 fork?
As you can see, I have no idea what I need. Any help would be very appreciated.
Also, if you know of any deals going on 120mm forks to suit - bolt through please feel free to share.
Thanks 🙂
Posted : 22/11/2020 5:46 pm
There are both 27.5+ forks and forks that will take either 27.5+ or 29. Depends on the brand. A normal 27.5 will be too small.
Posted : 22/11/2020 5:58 pm
I have some X-Fusion sweeps that are 27.5" non-boost and they take a 2.8" Nobby Nic on a 40mm wide rim, with no interference at full compression.
A bit of a squeeze but do go in safely - you might get a pair cheaper than the usual main brands.
You can adjust the travel but not sure if they go down to 120mm.
Posted : 22/11/2020 10:08 pm
The McQueen is xfusions proper 27.5+fork.
Posted : 22/11/2020 10:27 pm
 iolo
Would a 29 fork work?
Posted : 23/11/2020 8:17 am
Depends which one. A lot will yes. Post the fork you are thinking of. Well need to be a boost fork to have proper the clearance (done mind boost may work but it'll be a bigger and it's likely you'll have a boost wheel).
FWIW I have a set of 27.5+/29 Manitou Machete comps with a 3" WTB tyre set at 120mm. They were not that expensive and feel much better in use than their cost suggests they should.
Posted : 23/11/2020 8:28 am
