26" wheels and fork...
[Closed] 26" wheels and fork in a 27.5" frame?
13 Users
Will it go? For example, would transferring a 26" build to a 2015 Chameleon frame mean geometry would be ok and you'd have more tyre clearance for bigger rubber?
Posted : 06/02/2018 3:38 pm
How much would it drop your bottom bracket (and therefore your pedals)? Work that out before you go any further.
Posted : 06/02/2018 3:41 pm
I've wondered this. Something to do with getting a brand new set of 26" Enve wheels for free.
Posted : 06/02/2018 3:49 pm
IIRC it's slightly less than 1" change in diameter, given the same size tyres and width of rim.
So it'll be slightly less than 1/2" bottom bracket drop......... I'd just do it.
Posted : 06/02/2018 4:03 pm
Oh, and clearance width wise would be virtually unchanged in the vast majority of cases. So you'd not suddenly be able to put 26x2.5" tyres in a frame designed for 27.5x2.3. You'd only gain a mm or two. (some frames you may even lose slightly. But again, only a couple of mm)
As for the forks, it's all done to A-C length, as long as the 26" fork sits within the range of a comparable 27.5 fork, you'll be fine.
Posted : 06/02/2018 4:04 pm
I've got 26" wheels in my BFe275. Je n'ai pas died yet! The 130mm 650B forks (Auron) in it are actually shorter A-C than the 130mm 26" forks (Vengeance) I have.
So, to conclude, the world won't end, you won't die and the sun will still rise tomorrow if you put 26" wheels in a 650B frame.
edit- and there's ****ing hods of mud clearance in the back.
edited again- and it'll just take 26x2.8 WTB Rangers.
edited again- Flare with 26" wheels was fine, Rocket with 26" was fine, Soul 26 with 26+ was, you guessed it, fine...
Posted : 06/02/2018 4:16 pm
A lot of chainstays are indented where the tyre is supposed to sit - wrong wheelsize might mean your tyre sits near a wider part of the stay so you might have less clearance
Chances are th lower BB will be a good thing.
Posted : 06/02/2018 4:28 pm
I'm sort of wondering whether to go Liteville on my 26'er Rocket and put a 650b fork/wheel  at the front...
It's currently running 150mm 26er wheels, and without doing any sums I'm wondering if 140mm 650b wheels would result in very little geometry changes.
Posted : 06/02/2018 4:30 pm
 poah
I built a transition scout up for my son using 26inch wheels and fork. Running 10mm more on the fork to compensate for the a2c difference
Posted : 06/02/2018 8:45 pm
If only GW was here!
TBH I'd say if it works, it's because the BB was too high. But that's often the case anyway
Posted : 06/02/2018 9:20 pm
 rob2
I use 26” wheels in a Santa Cruz heckler 650b frame
Pros - it’s fine
Cons - to make it fine I had to move to 170mm cranks to give a bit more ground clearance
I think a chameleon would be fine
Posted : 06/02/2018 9:35 pm
I recall Cotic said on a Rocket it would drop BB by 14mm .... let me check ... so found this
http://www.cotic.co.uk/news/2016/26aintquitedead
It is worth noting they used 26 wheels with 275 forks
Posted : 06/02/2018 10:48 pm
Pros – it’s fine
Cons – to make it fine I had to move to 170mm cranks to give a bit more ground clearance
Exactly my experience but with a Transition Bandit 27.5.
bandit
I've got 26" wheels in a bird Aeris. Forks are 26" but at 160mm they are the same axle to crown as 650b pikes at 150mm so geometry is within design tolerances. BB's a bit low but it's fine until I can get the cash to build up some 650b wheels. Whilst the forks will fit the 650b wheels, the offset will be a bit off...but not so much for me to buy new forks!
Bottom line: you'll be fine!
Posted : 06/02/2018 11:14 pm
 poah
Using the smaller offset forks is all the rage the now anyway
155mm cranks so shouldn't have any issue with pedal strikes and there is an one-up bash guard on there as well.
Posted : 07/02/2018 2:26 am
