As the title says really.
looking for some 160mm 26" solo rct3 pikes.
does anyone one know of any good deals, been looking but wondered if anyone on here can help?
thanks
It may be worth looking within the EU shops for Pikes as they often knock them out cheap.
That's if you're sure you want RS...
I got a pair of RC Pikes from Altricks earlier this year. 26" 160mm.
Recommended.
Merlin seem to have some in 26" for less then £500. I also got an email from them today that went along the lines of 'payday deals, 10% extra off RS' but didn't investigate further.
Not 160mm but 150mm:
http://www.rczbikeshop.co.uk/uk/rockshox-2015-fork-pike-rct3-26-disc-solo-air-150mm-maxle-15mm-tapered-diffusion-black-00-4018-649-000.html
I got a 5% off code for alltricks FID0715
Code ends at midnight
The Merlin ones are 160mm and £480.
Alltricks ones are £407 plus shipping..
Minus 5% before midnight..
If 150mm ones are cheaper its only a £20 air spring change to convert to 160mm, then you have both options. http://www.gabelprofi.de/en/RockShox/Spare-Parts/Air-Shaft-PIKE-Solo-Air-160mm-travel-26-150mm-travel-27-5-can-be-used-to-change-travel-to-160mm-on-26-150mm-on-27-5-A1.html
