24'' Boys...
[Closed] 24'' Boys bike build help
11 Users
I am building my youngest a bike based on a spesh hotrock 24.
Has anyone found any decent forks for this? Preferably rigid and light.
I also have an Isis race Face bottom bracket that sounds like it has no grease whatsoever, is this serviceable?
Otherwise with a resprayed frame, new cables, and some bling, I'm good to go.
Posted : 18/07/2013 7:22 am
 ianv
You can stick a normal 26 in fork on a 24 in bike with no issues. A cheapish air fork would be fine ( and way better than a rigid one)
Posted : 18/07/2013 8:42 am
You considered keeping it light and chucking on some carbon exotic rigids?
Posted : 18/07/2013 8:46 am
I'm doing this too (GF Preclaiber)
The only 24" ones seem to be the ones Scott use on the high end 24" bike and what Isla are using on their bikes. I cant find them retail anywhere, too expensive anyway.
I have tried some 26" air forks and it makes a dramatic difference to the rake, puts an XC bike into AM maybe DH terrritory. Adults might not think its so bad, but if you think of it in % terms for a kid, actually its a huge difference (for example, the weight of the average half decent bike for a young kid is something like 45% of their body weight, compared to 17% for an adult).
I have some 26" carbon forks, the rake is still the same so i'm going to cut them down and re-bond them (yes I do have a clue what i'm doing).
Ergo - best option out of the box is but some 24" carbon forks from Exotic.
Rims? Dont get me started on rims......
Posted : 18/07/2013 10:21 am
I can't beleive on-one haven't tapped this market.
I can't use a 26'' fork as the brake bosses will be wrong, and I don't want to change the hub to disc.
Really, the Isla would be perfect. I might ring them to get a price on some.
Posted : 18/07/2013 10:33 am
I put these on my daughters Scott Spark 24" bike:
http://www.bike-discount.de/shop/k1024/a57905/f1rst-air-24-mtb-federgabel-schwarz.html?mfid=557
not that cheap, but work, have canti and disc mounts.
Posted : 18/07/2013 11:09 am
Nice
Posted : 18/07/2013 11:14 am
My kids Spesh has [url= http://tinyurl.com/p4g3qbr ]these[/url] on it. I reckon you'll find kids aren't as precious about the weight as Daddy is and would far prefer the fun of a pair of sus forks. I know mine would be most upset if I stuck a pair of rigids on his and told him it was to save weight!
ps. they WORK too.
Posted : 18/07/2013 12:06 pm
My lads Spesh 24 is about to get the 420mm carbon Exotics off his Mums bike. Just need to work out if the spoke lengths will be ok so I can build the wheel onto a Deore Hub I have. An old BB5 will be the disc brake for it. The stock Suntour forks weigh as much as a set of Pikes!!!
Posted : 18/07/2013 12:15 pm
dez i assume the suntour are spring
What i found is that i can barely compress my kids "suspension" forks never mind them so I am reluctant to get any tbh
What are these like for lighter kids?
The exotic carbon seem like the cheapest options
Mine did not mind the switch to rigid as that was what they had but with a weight penalty
Posted : 18/07/2013 12:27 pm
[i]What i found is that i can barely compress my kids "suspension" forks[/i]
Well as I said - they WORK. I always read something like this on STW when it comes to the wrong make of product! They work - they are decent forks for a child's bike that he'll be using for a couple of years max.
Wouldn't have bothered mentioning them otherwise.
Posted : 18/07/2013 12:34 pm
Not having a dig it is a genuine question [ they do happen occasionally ] as i will buy them
What weight is your kid as mine are floaty light so this might be part of the problem
TA
OH I was not referring to those forks at all those are not the ones on my kids bikes so sorry if it reads like i mean those forks dont work
Posted : 18/07/2013 12:39 pm
 st66
My boy has a Islabike Beinn 24. I'm considering "upgrading" this with a suspension fork - mostly because he wants his bike to look more like mine, and also his mate has just got a Spesh Hotrock which has a suntour fork on it.
DezB - how much travel is your kid getting out of the suntour? Does the preloading work? Any issues other than weight?
Posted : 18/07/2013 12:46 pm
This.
Both of my two have heavy bikes with elastomer forks which I have to work hard to compress (and I suspect that's the only time they ever move from full extension).
All of the rigid forks with v-brake mounts for 24" are either mega expensive or have a 1" steerer rather than the 1 1/8 that I would need.
st - perhaps your lad would like to make a straight swap!
Posted : 18/07/2013 12:51 pm
I've got a disc front wheel if you are short
Posted : 18/07/2013 12:53 pm
scottrider - Member
OMG! It doesnt matter how hard you try, someone on STW always out 'Googles' you!
Scott - I take it these provide some actual usable suspension then?
I'm pretty sure these are what Isla and Scott are using.
Posted : 18/07/2013 12:55 pm
[i]DezB - how much travel is your kid getting out of the suntour? Does the preloading work? Any issues other than weight?[/i]
Ha! You think I've [i]measured[/i] it?? He just rides it and has fun... they provide a nice bit of softness so he can ride up kerbs and over bumpy fields. 🙂
(I'll see if I can find a pic of the forks compressing)
Posted : 18/07/2013 1:01 pm
😆 found a pic - they are [b]RST[/b]s on the Specialized!! 😳
In my defence he had Suntours on his previous Haro bike - and they were good too 🙂
Posted : 18/07/2013 1:05 pm
I'll see what the RST's are like that are on there, can they be taken apart and cleaned/lubed?
I might weigh them just to see what difference we are talking about. Those air forks look mint.
Posted : 18/07/2013 1:40 pm
