2020 Debonair Airsh...
[Closed] 2020 Debonair Airshaft Sitting High at Rest
4 Users
Just fitted my 29/120 latest "2021" debonair air shaft to my A1 Pike RC. No problems fitting and it was a straight swap out.
But the forks at rest now measure 140 from the top of the fork seal to the underside of the crown.
The packet says 29/120 and A1/A2 Pike.
Have removed all air pressure and the stanchions will sink right down into the legs.
They seem to 'bounce' alright and ramp up near the end of the stroke. 4 volume spacers were and are fitted.
The initial travel is very soft and I wonder of this is deliberate and the actual usable travel is still 120 when sagged. Need to set up the sag as if it were a 120 fork and see how it rides.
Posted : 18/04/2020 3:42 pm
 poah
sounds like a mega upgrade with an extra 20mm of travel.
Posted : 18/04/2020 3:49 pm
With no air in what does the fork compress to? Is it possible that despite there being 140mm of stanchion only 120mm is actually used at full compression?
Posted : 18/04/2020 4:15 pm
Nope they go all the way down, thanks
Posted : 18/04/2020 4:22 pm
Sounds like you've got the wrong shaft?
Posted : 18/04/2020 4:31 pm
