2019 stumpy anglese...
[Closed] 2019 stumpy angleset or air shaft
7 Users
Im getting to grips (ish) with my stumpy and considering fitting either a 160mm air shaft or an angle set. Ideally if like 0.5-1deg slacker.
The air shaft seems like the most sensible and cheapest solution. But the instructions seem to give a part number for the 27.5 and 29er as the same.
Can i just swap my 150mm shaft out for a 160mm?
Posted : 02/01/2019 1:55 pm
Pretty sure thats the case case with all the new evol forks..
Posted : 02/01/2019 2:05 pm
Pretty sure you can't put an angleset in a Stumpy, there is no headset cups, they are moulded directly into the frame and the bearings sit on them.
Posted : 02/01/2019 2:13 pm
thats what i thought hobnob but i thought id ask.
its a pike
Posted : 02/01/2019 2:39 pm
so just purchase air shaft and swap out?
Posted : 02/01/2019 2:55 pm
Have you taken forks apart before (lower leg service?)
Posted : 02/01/2019 3:50 pm
Assuming they still use a yoke at one end of the shock, you could pop a single offset bushing in to reduce the HA by close to 0.5 degree.
I'd recommend Bounce's offerings...
https://bouncecycles.co.uk/book-a-service/offset-shock-mounting-hardware-offset-bushings/
Posted : 02/01/2019 3:55 pm
yup had pikes apart before.
Posted : 02/01/2019 4:27 pm
 poah
A 160 air shaft on a 26 is the same as 150 on a 27.5 and a 140 on a 29er with the original pike
Posted : 02/01/2019 4:35 pm
thats what i thought.
so whats the part number for a 160 29er?
Posted : 02/01/2019 5:15 pm
Is this already on the slack setting at the yoke? It has a flip chip you can rotate to alter angles
ere
https://goo.gl/images/YNLYUa
Posted : 02/01/2019 5:30 pm
already done that
im quite fancying the longer fork tbh
Posted : 03/01/2019 1:28 pm
