Hi guys.
Looking for some help and advice .
I bought a set of 2017/18 vision team 35 comp road wheels late last year and I am struggling to take of the freehub body
I have managed to get the axle and one sealed cartridge out on the non drive side but the frrehub body as a sealed bearing built in it again taped this out with the rubber cover seal just leaving the freebie body on the hub.
So I did a bit of web searching and come up with a 12mm Allan key which I tried and it fits but just carnt undo it I have tried it clock wise and anti clock wise but just won't budge .
Is there something I am missing is there a special tool or does it just not come of which I don't believe it doesn't.
I am at a the point know where am getting frustrated
There isn't a lot of info out there on the web explaining how to take these apart so know I am looking for some help or to put me in the right direction.
I any has got a set of these or had to change the freebhub body
Could you please give me the run down and also what kind of freebie body I mite need if anyone can help it would be deeply appropriate
Many thanks in advance.
Pictures at bottom
https://flic.kr/p/FvuCCW
