2017 Whyte 605 - Wi...
[Closed] 2017 Whyte 605 - Wider front tyre?
4 Users
Hi,
My 2017 Whyte 605 came with WTB BeeLine 2.2" tyres. I'm looking to put something a bit wider on the front. Has anyone changed and if so what did you put on?
Thanks 🙂
Posted : 15/12/2017 1:58 pm
Dunno if it's the same get, but I run a 2.4 HR2 up front on my 901.
Suits the bike really well 🙂
Posted : 15/12/2017 2:12 pm
Rims are 19 mm inner width?
Clearance of fork / frame?
If there is enough clearance a 2.35 inch tire would be still fine for 19 mm rims.
Good tires for this time of the year: Magic Mary? 27.5 x 2.35
If the frame / fork won't allow for 2.35 inch tires and if you don't need these fat studs: Nobby Nic 27.5 x 2.25 ?
If 2.3 inch is possible WTB Vigilante? 27.5 x 2.3 Vigilante is a good pick.
Magic Mary and Vigilante: trail biking, all mountain stuff
Nobby Nic: not as fat studs as above - but definitely better tire than WTB BeeLine
Whyte states something about max tire sizes?
Posted : 15/12/2017 8:53 pm
Right now 2.2 inch tires?
Rear: switch to the smallest gear possible. Check clearance to chain, chain stay and seat stay
Front: how much clearance is between fork and side studs of the 2.2 tires?
When moving up with the tire size leave enough 'safety'. A 2.3 inch tire might be bit wider than 2.3 inch...
Posted : 15/12/2017 9:30 pm
I've got the same bike and I've put 2.35 tough toms on front and back.
Posted : 16/12/2017 5:29 pm
Great!
2.35 inch will be much, much better than the original:
WTB BeeLine 2.2"
Posted : 16/12/2017 5:45 pm
Again, if the frame is similar to the 901, be cautious of clearance on the back. I stuck a 2.4HR2 on the stock rims of my 901 (21mm internal I think) and it was buzzing the chainstays. The Ardent (possibly a 2.35? Can't remember, don't know if that even exists) I put on there instead is very close as well.
You might be ok with a narrow 2.35, but something like a Magic Mary would have no chance.
Posted : 16/12/2017 6:24 pm
Thank you guys for the help and guidance. Think I might play it safe and go with 2.3, something like the Vigilante.
Posted : 21/12/2017 9:58 pm
Great!
Something you might consider:
WTB Vigilante 27.5 x 2.3 in CLINCHER TIRE version.
Won't be as low weight and "great" like the folding vigilante (?).
But got a clincher version in winter sale. An it's great!
O.k. - not so easy to get on and off the rim.
But for the money A BLAST.
Posted : 22/12/2017 3:14 pm
