2015 salsa warbird ...
[Closed] 2015 salsa warbird 700c - running 650b wheels and mtb tyres
4 Users
Hi
I did ask salsa and they said no (because they hadn’t tested the combination) but is there any reason not to stick 650b wheels and 2.25 tyres in a salsa warbird, which currently runs 700c with 40mm tyres (assuming there’s enough clearance)? Is clearance likely to be an issue
Thanks
Posted : 25/11/2019 3:35 pm
Only one way to find out.
Posted : 25/11/2019 4:15 pm
Not sure if it’s any help to you but I’ve run 650b x 2.1 in my 2017 Vaya, had intended to build up a spare set of 650b wheels but ended up with a new Salsa El Mariachi so sticking with 29er.
(I’m selling the 650b rims if you’re interested)
Posted : 25/11/2019 5:31 pm
 jon2
It will work with a pretty fat tyre although I don't know about all the way up 2.25"; you might need to go slightly thinner on the tyre. I have used a 650bx38 (1.5") and there was loads of clearance, but probably not an extra inch - or if it fits, just, you might get problems in mud:
Posted : 26/11/2019 1:44 pm
ive just tried it with someone else's wheels and 2.1's don't fit. It's currently on 700c with 40mm tyres
47mm on 650b would probably go
Posted : 26/11/2019 9:22 pm
