I have an issue with my BB on my 2015 Spectral AL 7.0ex
Sounds very much like the issue raised in this thread (Where no solution was posted)
singletrackworld.com/forum/topic/any-canyon-spectral-al-275-owners-here/
I have a spacer installed between the BB and crank (2.5mm) which is loose fitting and according to SRAM should not be there - t causes issues tightening the cranks but works if centrally aligned - without the cranks foul the frame.
Would appreciate some help, dontknow if it was this way from new but only picked up on it recently...
Thanks
Tom
If its the same as the link you posted, I would put the spacer between the BB and the frame (on the non drive side) and refit your cranks. It should be fine.
