Need some new (rear) bearings but having trouble working out what size to order and what I need. Was thinking Id replace the fronts at the same time.
Does anyone know what size/specs I need?
Hi Freeride_addict,
There are 4 bearings in each Oozy rear hub, 2 in the hub body and 2 in the freehub body. The bearing size for all is #6902. There are 2 bearings in each front hub, which are size #6804. Replacement bearings can be purchased from Spank or Hotlines UK (our distributor). If you need an exploded view drawing or contacts at Hotlines, please email us at info@spank-ind.com
Mike. Do the older spank oozy wheels (2013 al26) have same 4x 6902 bearings in rear hub?
