2013 Rockshox sprin...
[Closed] 2013 Rockshox spring internal change
8 Users
A continuation to my last post i guess........
Think i have opted to go for 2013 RS Revelation SoloAir 140mm 29er's for the Solaris.
Has anyone got experiance of changing the spring internals to lower them to 120mm?
Wondered if it was do-able by myself.
Cheers,
Alan.
Posted : 11/11/2012 10:52 pm
Dead easy, you just install the small cotton reel shaped plastic bits that came with the fork in the spring side.
Posted : 11/11/2012 10:59 pm
 v10
Its unlikely as the kits haven't arrived with SRAM Tech in the UK yet. Its just refitting the solo air spring so will be pretty simple.
Lowers removal, top cap removal (24mm socket), spring assy removal (you will need some decent circlip pliers for this) and then it will all go back together the way it came apart. Will need a few ml of 15wt fork oil to relube the lowers too.
Posted : 11/11/2012 11:08 pm
 v10
TINAS the new 2013 solo air forks need a complete air spring assembly to change travel not just the plastic spacer.
Posted : 11/11/2012 11:09 pm
Success 😀 See my post here [url= http://singletrackmag.com/forum/topic/revs-can-the-travel-be-shortened ]Revelation from TF Tuned[/url]
I've bought the fork direct from TF, modified to 120 mm travel. Did'nt ask what was involved. Very good price for you my friend 😉
D.
Posted : 12/11/2012 11:18 am
hmm wow that's quite a downgrade/downside if you can't adjust travel with just spacers any more 😮
Posted : 12/11/2012 11:21 am
Loco Tuning will also fit the spring of your desired travel for a very good price, when they come into the UK and he is back from paternity.
Fitting the old school spacers does shorten the travel... but removes the negative spring from the system! Bit annoying RS have made it more expensive and difficult to experiment with travel, but that's progress.
Posted : 12/11/2012 1:27 pm
is it progress though? does the 2013 air spring do anything better? good for LoCo, obviously 🙂
Posted : 12/11/2012 2:08 pm
All I did with dual air was try to make the pressures the same in each chamber, and the -ve leaked within the duration of a ride for me, so it is progress in that sense. If you liked to run different pressures in each chamber, its a step back.
Posted : 12/11/2012 3:41 pm
Just ordered mine from Winstanleys - nowt the wife can do about it now! 😉
Paid £520 posted and they only had one pair left.
According to Fishers the travel is adjusted down by fitting a spacer you get supplied with the forks?
Will need to wait and find out, should have them by the end of the week 🙂
Then project Solaris trail bike will be complete - making way for project Ibis Ripley next year 😉
Posted : 12/11/2012 5:17 pm
'Old' rs solo air spring (circa 2004-9) could also be shortened with all travel spacers. What's changed?
Posted : 12/11/2012 5:26 pm
If they are 2013 solo air you need to change the entire spring assembly to a shorter one of your choice, iirc £75 for the new unit.
as per http://singletrackmag.com/forum/topic/rockshox-2013-solo-air-travel-reduction-critical-problem
Posted : 12/11/2012 7:13 pm
bigjim - 18bikes told me what you have posted above, but Fishers say different???
So im really confused 🙁
Wait and see when the forks arrive at the end of the week.
My local Alpine Bikes at Glentress said they could do it and are very knowledgable and trustworthy, so im taking them there.
Cheers.
Posted : 12/11/2012 7:23 pm
YOU DON'T NEED AN IBIS RIPLEY!!
Posted : 12/11/2012 7:28 pm
Nice tho................
Posted : 12/11/2012 7:52 pm
Hmm if u say so.. Better of with a Nomad. Maybe u should get one of those...
Posted : 12/11/2012 8:18 pm
But you did NEED to sell an orange Mk.2 Soul to build another orange Mk.3 Soul.....
Posted : 12/11/2012 8:21 pm
The message from TF was that the fork can be modified to 120mm travel. However if I ever want to return them to 140mm it will necessitate buying new bits to replace the part/s that they've modified. Not sure about fitting a spacer ! Also according to TF the Dual air model cannot be shortened.
Don't shoot the messenger 😀
D.
Posted : 13/11/2012 8:57 am
It was TF that told me to convert to 120mm, they would fit a spacer.
It's the Dual Position (DP) model, rrp. £750 and only available in black that are fixed at 140mm.
I opted for the Solo Air RCT3's, same as u.
Will have mine tomorrow, as they got dispatched this morning Parcelforce 24.
We will b bouncing on 120 soon enough my friend.
What bike r urs going on?
Mine r for my Cotic Solaris.
Posted : 13/11/2012 12:23 pm
Yes I did... To answer your earlier question.
Posted : 13/11/2012 12:25 pm
Aye, same here, Solaris in LIME GREEN 8) It's the fork that's been holding things back. After I decided on Tapered, 120mm, through axle the choices seemed to evaporate. I've never owned a set of Revs, but my mate the "Yak" has a set on his 456 & they've been bombproof in the face great adversity & nil maintenance.
Canny wait 😀
Posted : 13/11/2012 1:48 pm
No way! - Mine is lime green too! 🙂
Currently built with eXotic carbon rigids.
Post pics when it's ready and I will do the same.
Posted : 13/11/2012 6:16 pm
Alan you have PM 8)
Posted : 13/11/2012 8:34 pm
