Just wondering, I'm having difficulty with pressures as some initial stiction delays the Neg pulling the stantion down until 150psi in the neg chamber.
So, is their anyone 13st kitted up that can comment on their pressures - I'm getting 25% sag at 80/85 pos/neg...? Fork feels stiff though.
Bump?
I'm starting to wonder if the SID just isn't an weekend warrior "plush" type of fork, I guess so anyway with its intended use in mind.
FYi, 75+ / 85- seems to be todays setting (rising in mud) at 82kg with 4 click of LSC.
Any comparison from anyone else?
I have 2010 SIDs and when generally trundling about I have to run both chambers well below the recommended pressures. I'm about 82kg and run about 90lbs in both chambers.
I think you might find that your R2 unit has a bad motivator.
