2011 Mavic Crossmax...
[Closed] 2011 Mavic Crossmax SX axle conversion
4 Users
 qtip
Does anyone know if a 2011 Mavic Crossmax SX can be converted from a 142mm axle to a 135x12mm one and, if so, where I can get the appropriate kit from?
Posted : 08/03/2013 2:13 pm
Have a look at this thread (and some of the links...)
http://singletrackmag.com/forum/topic/mavic-crossmax-135-12-adaptors-where-to-get
might help.
EDIT: FWIW, it looks like (according to the parts diagramme) that it is just a case of taking off the existing 142mm converters and hey presto, 135mm spacing. Think they are threadlocked on though so it might not be obvious.
Posted : 08/03/2013 2:16 pm
 qtip
I saw that post, but that seems to be for the older style hub. The 2011 uses the ITS4 hub and I'm not sure if the same principle applies - can anyone confirm or deny?
Posted : 08/03/2013 2:26 pm
 jimw
If it is the same ITS4 as my crossmax 29ST, you just pull the adaptors out and it is 135 x 12.
Posted : 08/03/2013 2:41 pm
I have the 2012s, and they come with a 142 adapter as standard, and they are ITS4 hubs. Removing the 142 makes them 135 AFAIK
Posted : 08/03/2013 3:00 pm
