Can anyone tell me the factory tuning for a Fox RP23 BV (XV air can) on a 2010 Five?
Im after compression tune, rebound and boost valve.
cheers!
The tune on my 2010 Five is firm compression/velocity, medium rebound and 225psi boost valve pressure. The tune on my wifes 'early' 2010 Five is medium compression/velocity, medium rebound and 175psi boost valve.
Both shocks are RP23BV(XV)as they came from the factory. Tune on mine gives better slightly pedalling behaviour and more of a ramp up on bigger hits, whereas the tune on the wifes shock is more sensitive to small bumps and has a more linear feel on big hits (doesn't bottom out nastly though).
HTH.
