Any ideas what headset I would need for this frame? I've bought the frame with no headset and want to make sure I'm ordering the right one. Cheers
Hope Integral is the headset I have in my Zesty of that vintage.
2010 Zesty's took an 1"1/8 semi integrated (or at least my carbon 714 does)
Is semi integrated the same as integrated?
No. Integrated headsets have the bearings sitting directly Into the machined head tube, semi integrated bearings sit in the frame but in separate bearing races.
I'd recommend getting the headtube measured with a vernier caliper, Lapierre have been known to use some odd size cups on some of their frames.
I run a works components angled semi- integrated headset in my 2010 zesty 914 - works a treat !
Pretty sure its a 44mm headeset. Thats what my spicy needed anyway.
Also means you can run tapered forks with a 44EC lower cup.
