2009/2010 Fox Talas...
[Closed] 2009/2010 Fox Talas oil change
2 Users
I have decided to carry out an oil change on my forks and would like some advice having read the tech pages on the Fox website. So as it's only an oil change do I need to take the Talas bobbins out and I'm bit confussed about putting the oil back in on the lockout/rebound side?
Posted : 15/02/2011 12:28 pm
 LoCo
No leave Talas side alone unless changing seals the talas unit seals and you may need a Talas charging tool too for this depending Talas System fitted (I,II or III), drop lowers off and remove damper cart. to bleed it.
Posted : 15/02/2011 12:29 pm
Mr LoCo I can leave the damper bit in the fork leg and just push it up and down?
Posted : 15/02/2011 12:34 pm
 LoCo
You can but it doesn't really purge all the old dirty oil out that well. You need a 26mm 6 sided socket (ideally machined flat) for the top cap.
Posted : 15/02/2011 12:37 pm
Million thankyou's, will look in the garage tonight if I can't find one I will purchase one from yourself.
Posted : 15/02/2011 12:42 pm
 LoCo
No probs. drop me a mail if you have any issues 😀
Posted : 15/02/2011 12:50 pm
