2009 Rockhopper Pro...
[Closed] 2009 Rockhopper Pro suspension travel?
3 Users
I've got a mate's bike in for a service and the forks are in bits. They are Reba SLs, with 100mm travel, but have a 20mm spacer inside so will go out to 120mm.
Anybody used 120mm on a Rockhopper?
Good?
Bad?
Indifferent?
Cheers! 😀
Posted : 11/03/2013 9:27 am
I've put 120mm Rebas on my 2006 Rockhopper which I think is the same geometry. Took about 10 minutes to get used to the slight change in handling, and I think the extra travel is an improvement (although it could well be the bike equivalent of the placebo effect).
Posted : 11/03/2013 9:31 am
Cheers!
Posted : 11/03/2013 9:35 am
Good timing with the question PP. I've just bought a RH frame to build up and was wondering the same thing..
Posted : 11/03/2013 9:36 am
Forgot to add that the extra travel will definitely wrench the head tube from your frame, killing you instantly.
Posted : 11/03/2013 9:43 am
Not ME it won't. Not my bike, see....?
I used to have a 2004 Stumpy FSR and they were renown for liking a bit more travel up front. I went from 100mm to 115mm Rebas and it was perfect.
Posted : 11/03/2013 9:54 am
