hi,
just bought myself a pair of these the front one is perfic nearly chucks me over the bars but the rear is shit the lever can nearly be pulled to the grip before it sort of stops you... it works better if you pump the lever before you want to brake but soon goes back to the shit state again when you pull the lever there is a quiet popping sound is this a lack of fluid or is there a leak (i cant see one?)
cheers tom
Low fluid, air in fluid or contaminated pads?
There's air in it. It needs bleeding
Tom, Do you want that heatshrink then?
yeh how much have you got? and how much are you wanting?
tom
Brake needs bleeding. Very simple and straightforward
About 3 metres. Send me an address and you can have it as a late Xmas pressy.
onion ygm!
so it looks like they just need a bleed?
If you get stuck give us a bell
+ are you using that light?
yeh im stuck and i was going to go out riding on sun am and i havent used the light for a week or so if you want it back?
tom
