I have a pair of Reba SL's from 2007 currently 100mm travel, this can be increased to 115mm by the removal of a spacer on the air shaft.
What I am struggling with ( I have only had 2 hrs sleep since 06:30 yesterday) is will the extra 15mm lift the front of the bike up by that amount?
Posted : 08/06/2022 12:03 pm
yes it will jack up the front of the bike
Posted : 08/06/2022 12:28 pm
Only when stationery, sagged @ 20% the fork - when set at 100mm - will give you 80mm of travel, sagged @ 20% - when set at 115mm - will give you 92mm of travel so the front end will be 12mm higher.
Posted : 08/06/2022 12:46 pm
