2002 Fox Forx Float...
[Closed] 2002 Fox Forx Float 80 RLC Travel Spacers
2 Users
 Tim
Afternoon!
Long shot, but...
I'm after two 20mm travel spacers for a 2002 float fork I'm using on a retro build (to drop the travel to 60mm).
Anyone have any, know of any where that sells them or knows of a suitable alternative?
Tim
Posted : 01/03/2020 3:06 pm
Hiya.
I've just done this for some forks a friend kindly donated for one of the Udderlet's 24" wheeled bikes. I dropped the travel to 63mm on a pair of Float 100s using only a single Rock Shox Reba spacer. If you have the same sort of air shaft as the ones I adjusted, you should be able to reduce the travel without using spacers.
Here's how:
Pinkbike Adjust Fox Floats using the push pin rather than the spacers
Posted : 01/03/2020 4:04 pm
 Tim
That's great, thanks! I did notice that extra pin hole but wasn't sure if that could be used or not.
Need to measure but from memory it is ~20mm difference on my fork between the pin holes. But if you can use a Reba spacer then these are more available...
I was tempted by a bit of conduit though 🙂
Cheers for the help
Posted : 01/03/2020 4:53 pm
