2 x 9 - experiences...
[Closed] 2 x 9 - experiences with 26/40 up front
4 Users
 cp
I'm currently running 26-36 on my 9(18) speed 29er, and want to try a 40T instead of the 36. Anyone run a 26-40 set up? Is shifting still OK between the two rings?
Thanks, Chris
Posted : 12/09/2013 9:06 am
I was lead to believe that 9sp front mech will do up to 14t jumps. I ran 22/36 so it should work...
Posted : 12/09/2013 9:09 am
 mrmo
i think i run a 26/40 with TA rings and it works, don't use the 26 much so tend not to worry about the shifting.
Posted : 12/09/2013 9:15 am
I have 27/40 with an XTR shifter.
Seems OK but I don't shift it too much, the faster shift is to the 27 cog when I have hitting some gradient, shifts the other way are normally on the flat so I have more time.
Posted : 12/09/2013 9:20 am
 cp
Thanks folks, might just give it a try then - I'm spinning out a bit on the 36.
Posted : 13/09/2013 7:13 am
