2 rides old and sez...
[Closed] 2 rides old and sezied, what would you do?
23 Users
 spev
Im not going to name names (yet) but I have a product that has seized after 2 rides, i've been told that I will need to service it regularly (which I accept) but surely 2 rides (about 3 hours each) is a bit poor? Should I take it apart as instructed or just send it back?
Posted : 22/07/2009 1:54 pm
I'm going to have a wild guess and say is it rockshox sids?
Posted : 22/07/2009 1:56 pm
Return as "unfit for purpose"
But without a bit more detail its hard to say. Service it regularly? What is regularly? If its a sealed bearing then no amount of servicing will help.
i'm guessing it's "the day"?
Posted : 22/07/2009 1:57 pm
ks i900 by any chance?
 Smee
What TJ said.
Posted : 22/07/2009 1:58 pm
 nuke
Fine you can't name names but what component is it?
Posted : 22/07/2009 1:59 pm
 spev
if i say what it is, then you'll know who it is 🙂
its not sids though.
The problem is I'm not keen to take it apart and service it so soon after getting it (2 weeks 2 rides)
Whilst accepting I'll need to service it im not happy that its locked solid after the second ride (it worked fine on the first one)
ah well i'll get back in touch with them and see
Posted : 22/07/2009 2:04 pm
Yes I think this depends on the component! Are we talking something with bearings like bottom bracket, hubs etc, or is it fork/shock or sommat!?
It sounds like it's not fit for purpose, but it's hard to comment without knowing more!
Keep us informed please
My guess is that it would fail the "fitness for purpose" test - if its seized it is ruined I would have thought. I can think of no MTB component that could be reused after seizing without replacing bearings.
Posted : 22/07/2009 2:08 pm
 spev
Similar to a fork/shock, I think the seals (Whilst I accept they are cheap) suck more water in than they stopped.
Posted : 22/07/2009 2:10 pm
It's not practical or realistic for that matter to have to service a BB every 2 rides ffs.
Send it back.
*I guessed it was a BB :mrgreen:
Posted : 22/07/2009 2:11 pm
 nuke
[i]if i say what it is, then you'll know who it is[/i]
Thats what I was hoping 😈
Posted : 22/07/2009 2:12 pm
Spev - you are right - now we know what it is 🙂
Is the retailer seriously suggesting it needs to be serviced every ride? As it seized on the second ride this would seem to be the case.
So - its definately not a K900 seatpost from Superstar then 😉
Send it back.
Posted : 22/07/2009 2:13 pm
 spev
cheers all , i'll get it back and let you know the result
Posted : 22/07/2009 2:14 pm
i think brant would like to know of you experiences and if you do bin it i reckon hed like to take it apart too
Posted : 22/07/2009 2:15 pm
Well I think we need to know what it is before any accurate advice is given. But if I bought anything and it only lasted 2 rides it would be mere minutes until I inserted the failed component into the makers natural biological output chute.
I'm guessing one of those Hydraulic height adjustable seatpost thingies.
Posted : 22/07/2009 2:16 pm
threaten to burn the manufacturer's facility down.
Posted : 22/07/2009 2:25 pm
Did you fit it with a rock?
Posted : 22/07/2009 2:26 pm
 spev
cheeky git Barry 😀
we fitted it on the workshop at the cycle shop where I work with the intention of testing "it" before maybe stocking them (wont be now)
Posted : 22/07/2009 2:52 pm
 spev
right i've decided to persevere and clean out the post. Its working fine now, the problem was water had run down the stanchion causing it to fill up and lock. Although I'd expect it to last a bit longer between services perhaps riding in Afan during the wettest sunday for while with no rear mudguard or protection on the post was a bit daft.
Either way I'm going to give it another go as it was very useful the week before.
I've already apologised to the company in question as I figure my stupidity does'nt give me carte blanche to openly criticise on a forum without giving them a chance to help me first.
Right im off for a cuppa and self flagellation in penance 🙂
Posted : 22/07/2009 10:10 pm
A mtb part for should be able to cope with water. If its seals were any good it wouldn't have happened.
Posted : 22/07/2009 10:13 pm
 spev
Yeah I thought that but I would use a shock in those condtions without a cover of some kind so I'm giving it the benefit of the doubt.
If it seizes again then thats a different story
as for stocking it at the shop, i'd like to but I guess most of our customers (who dont even clean their bikes before they bring them in for a service) would destroy it by looking at it. We had one guy killed a front mech in 1 hour after leaving the shop (and he killed it , it was'nt a manufacturing fault)
Posted : 22/07/2009 10:20 pm
How do you kill a front mech in an hour? Short of hitting it directly with a rock, I can't see how it could be anything but a manufacturing defect.
FWIW, this post would seem to be totally unfit for purpose. It doesn't matter what the explanation is it should be able to survive a wet ride, or twenty. Sure without maintenance things wear out faster, but there are reasonable limits.
Posted : 22/07/2009 10:29 pm
if its a joplin my mate had exactly the same experience as you, he took it back and swapped it for a rigid carbon post
Posted : 22/07/2009 10:31 pm
 spev
Well it appears he rode out of the shop, fiddled with the stop screws (no need to but he though the chain was rubbing-but he was running big-big so the chain was at an extreme angle) then when the mech wouldnt move (stop screws too far in) took an allen key to the cable clamp over tightened it snapped the screw, fitted a bodged nut and bolt and then twisted the cage trying to get it too work. Given that he was no more than a mile or so away we have no idea why he didnt come back straight away. He was rather sheepish when we finally coaxed the full story out of him 🙂
Posted : 22/07/2009 10:33 pm
Ah ok. Point taken. No accounting for stupidity.
Posted : 22/07/2009 10:36 pm
Geez, spev, you really can't legislate for that kind of utter stupidity. That really was dumb...
Posted : 22/07/2009 11:03 pm
 Smee
That post isn't fit for the purpose it was sold for. i.e. MTBing in the UK. If it needs a cover to keep the crap out of it then it should come with one. And yes I do use shocks and forks in pissing wet conditions with no covers on them and never have any issues.
Someone is bamming you up.
Posted : 23/07/2009 6:29 am
TJ is spot on there.....
Posted : 23/07/2009 6:45 am
I don't think so! It should be able to cope with that easily! Its not even been covered in mud!
You hadn't openly criticised at all...you hadn't even mentioned what component it was until that same post.
Posted : 23/07/2009 6:47 am
 spev
Point taken, but I figured most had guessed what it was, I do agree that the post should come with a sleeve or cover but I also think most MTB components arent really designed to work in the conditions we subject them to and we all seem to think its ok to defend them from the elements by whatever method we feel is best.
I always strip a new shimano hub and pack it full of grease even though you would expect shimano to have done it already (not always the case IME)
Anyway i'm going to give it another go, if it fails again (after I have sealed it up) then thats a different story. It's a good price for a reasonable product in comparison to the others on the market (which also have similar problems) so I feel I should give it a second chance 🙂
Posted : 23/07/2009 6:54 am
I had some of those hollow form PACE forks once, the first year they came out. if it was even mildly damp out they would compleatley lock out and need stripping down and an oil change, after about 4 rides were ruined by these pieces of crap i sent them back to pace, (cost me about 15 quid postage) i phoned them a few weeks later, they told me 'our mechanic has been riding them around for a few weeks and they work perfectly (complete BS as it was obvious they hadn't put them on a bike unless it was running a syncros headset, or put the crown race back on millimeter perfect from when i originally put it on' then they sent them back charging me for postage if i remember rightly. Pile of crap, never never never again. I felt bad about it but i ebayed them, with a very honest discription, taking a hit on the price, but jesus what a load of crap. I'm only saying this as superstar seem to have taken a page from (my experiences) of pace's customer service book, if they took 5 more they'd have enough to wipe thier arse.
Posted : 23/07/2009 7:39 am
"A mtb part for should be able to cope with water. If its seals were any good it wouldn't have happened"
Rohloff hubs anyone?
Sounds like as with anything product testing is being done on the early adopters.
Posted : 23/07/2009 7:44 am
Havent those posts been available for about a year. Hardly an early adopter then.
Posted : 23/07/2009 8:00 am
sorry if i'm being thick here but why don't they just use a proper set of seals? Fark it, use two sets! It's not like it needs small bump sensitivity is it?!
Posted : 23/07/2009 8:15 am
I think it was Rohloff in reply to one of SFB hub failures that suggested that they could have used better seals on their hubs, but for the vast majority of users around the world this would give unacceptable amounts of drag. Thing is Spev is about right, the UK (and more specifically, riders in the UK) use MTB products in conditions that other countries just simply don't have to think about. It doesn't rain from one year to the next in So Cal. In Europe in the winter they ski or whatever.
We pretty much have to accept the fact that we have to look after stuff, and sometimes that does mean after every ride, especially in winter...
Posted : 23/07/2009 8:23 am
Nickc - not in my experience. Nothing on my bike wont survive riding in winter.
Marzochi forks with proper seals, hope hubs and brakes
Posted : 23/07/2009 8:53 am
TJ, the same is true of my bike.
Doesn't make it any less true that some products sold in this country are developed and tested in countries that have vastly different conditions to us, and by people who've never experienced a British Winter, let alone ridden a bike through one. People complain about the price of stuff as it is, imagine the extra costs of having to develop stuff to specifically deal with just 4-5 months in one country...Anyway my seat post (non moving) doesn't seem to have any difficulty coping with wet conditions at all 😉
Posted : 23/07/2009 8:59 am
