2.30 DHF real width
[Closed] 2.30 DHF real width
8 Users
Hallo! How much is the real width (lug to lug) of the 2.30 DHF?
The ertro indicates 58mm.
I will certainly buy it if it is more on the 59mm width.
Just for reference, i have the 2.30 aggressor and it measures exactly 58mm lug to lug.
I also have the older DHF 2.50 supertacky, and it measures 60mm.
Posted : 25/05/2018 9:37 am
you can notice 1mm width on a tyre - impressive!
width will vary based on rim/pressure etc etc.
Posted : 25/05/2018 9:45 am
I am glad I checked this as I was searching for exact measurements for a 2.30 aggressor so thanks for that.
I can't give any info for a 2.30 DHF sorry.
maxterra or supertacky has better grip?
Posted : 25/05/2018 11:16 am
supertacky has better grip but rolls slower
Posted : 25/05/2018 11:18 am
The WT 2.50 will be ok in 23mm inner width rims?
Posted : 25/05/2018 11:30 am
I’ve got a 2.5 dhf wt on a 25mm internal width and thats ok - although that’s probably narrrower than the tyre is designed for. As a result my tyre profile is quite rounded - so probably more progressive in how it breaks away, but has less outright grip if you through it aggressively into a corner.
In terms of size it fits through my non boost Yari but it’s not got a huge amount of clearance through the brake arch.
Posted : 25/05/2018 12:11 pm
Maxxis WT are designed for 30-35mm rims but I’ve got one going on my Hope DH rim and that’s 28mm internal.
Posted : 25/05/2018 12:51 pm
WT is a no go for me.
The real question is, should i go for 2.50 supertacky exo or 2.30 maxterra exo TR?
The first is a bit heavier, probably with more grip-rolling resistance, and not tubeless ready. (i will install it in tubeless rims)
Is it wider than the 2.30?
Posted : 25/05/2018 3:35 pm
the 2.5 supertacky, will be fine for tubeless installation in UST rims? (the tyre is not TR)
Posted : 25/05/2018 6:48 pm
They are really small more like a 2.2, maybe 2.1
Even the 2.5 is smaller than 2.4 Michelin, Onza and Bontrager equivalents which are much closer to their claimed size.
Posted : 25/05/2018 6:55 pm
27.5x2.3 Minion DHF 3c maxterra TR on a Hopetech Enduro rim measures 57.9mm or 2.279" HTH😀
Posted : 25/05/2018 8:34 pm
27.5×2.3 Minion DHF 3c maxterra TR on a 25mm internal DT rim rim measures 57.8mm
Posted : 25/05/2018 9:34 pm
