1X9....don't r...
[Closed] 1X9....don't roll your eyes
29 Users
Will the chain simply come off if I don't use a device?
Is there any combo that'll run without one??
Posted : 14/04/2011 3:52 pm
Possibly not required if you ride smoothly on smoothish trails and have a sufficiently short chain and a short cage rear mech correctly adjusted.
You could always try it for a bit, and if you keep losing the chain, add a guard later? The superstar xc one is quite good value.
Posted : 14/04/2011 3:56 pm
The guide can also stop the bottom of your trousers getting sucked into the chain/chainring.
Posted : 14/04/2011 3:57 pm
If you use a unramped chainring and shorten the chain its not bad - I have run commuters like this with no chaindropping. its never an issue in gears 3-7 only at the extremes of the casette.
Posted : 14/04/2011 3:59 pm
On the road it would be fine. Off road I don't fancy your chances.
Posted : 14/04/2011 4:06 pm
As Teej says, commuters OK, however, in my experience going offroad over anything remotely rough and you'll lose the chain. I lost mine last night using a bashguard and an N-Gear Jump-stop, but then it was over a decent tree drop thing, so I shouldn't complain. I am looking for a pukka chain device now though.
Fair enough, though TBH if I needed a device I'd rather use a road double.
This is for this trail crosser I'm building, it's just that I don't think I use anything much more than a 34T.
Posted : 14/04/2011 4:10 pm
 Tim
Off road you need a top guide at the very least, but i've always found a lower gide is required as well, or you can lose the chain when you back pedal for corners or over really rocky stuff
Posted : 14/04/2011 7:58 pm
use the right chainring and right length chain and no device needed on or offroad,why put an ugly heavy device on and just carry it around when it's not needed? using this for 14 months with no chain issues and it's a standard length mech
[url= http://farm6.static.flickr.com/5230/5603457965_fe96cfee4b_o.jp g" target="_blank">http://farm6.static.flickr.com/5230/5603457965_fe96cfee4b_o.jp g"/> [/img][/url]
[url= http://www.flickr.com/photos/rocketdog/5603457965/ ]1 x 9[/url] by [url= http://www.flickr.com/people/rocketdog/ ]rOcKeTdOgUk[/url], on Flickr
Posted : 14/04/2011 8:02 pm
Try it and see. IMO RD is right - it might have been on my commuter but I would jump off several things on my way home
Back-pedal? WTF
Posted : 14/04/2011 8:16 pm
I tried it, chain was always falling off over any kind of rock or jump.
Posted : 14/04/2011 8:20 pm
IMO RD is wrong. Give it the berries over some roots eventually you'll drop that chain. there are some very nice looking, light chain devices. Can't see why anyone would want to run the risk for no good reason....
Posted : 14/04/2011 8:26 pm
As (a few posts) above, if you have rubbing noises on a 3X whatever set up you may need a device, if you don't then 1x whatever will be no problem, just make sure the chain is relatively tight when in the easiest gear.
HTH.
Posted : 14/04/2011 8:28 pm
cookeaa - Member
been riding locally (plenty of roots around here) natural Scotland and welsh trail centres, the secret is an unramped long tooth chainring, use a normal ring or even worse a ring designed to shift and it'll not work
Posted : 14/04/2011 8:36 pm
 GW
Back-pedal? WTF
for cornering prperly (you know, **** all like riding a motorbike ;). clueless old bugger! 🙄 oh.. and just out of morbid interest, WTF you "jump" off on your commute?
RD is sooooo wrong! 😥
Posted : 14/04/2011 8:51 pm
If you do have a problem with jumping- a bash guard and an n-gear jump stop will sort it out for not much dosh. Jump stops are about a tenner or so.
Posted : 14/04/2011 8:53 pm
 7hz
1x9, didn't need any devices on GT Red route running 1x9 with ramped chainring. Secret is to keep it around the middle gears on the cassette on the rough stuff.
Pulled it off the chainring to the outside giving it the beans from traffic lights in city centre in the 11 tooth gear though!
Have added bash + ngear and seems ok, although did loose it to the inside over some roots in t'pentlands. Need to adjust the N-stop.
No way do I want a chain device on a XC / trail bike, seems very unnecessary / ugly / heavy.
Pauls chain keeper is another option, I got one but my downtube is too big and so it can't get low enough.
Don't understand back peddling - why not always forward? Still half a rotation, and you maybe get to put some power down as well...
Posted : 14/04/2011 9:02 pm
 GW
no it won't
Posted : 14/04/2011 9:03 pm
GW - I always turn the pedals forward to get them in the right position. What do I jump off - a few lumps bumps speedhumps an kerbs I know on the common route home Only tiddly ittle jumps. Ie on leith street there is a large lump in the tarmac pushed up by buses about 10" high - makes for a nice wee hop
Posted : 14/04/2011 9:05 pm
 Robz
If you need back pedaling when cornering explained then you must crawl round the trails. You only back pedal a quarter of a rotation or so, but it's not always possible to pedal forwards the necessary amount in time....
If your going quick enough 😉
Posted : 14/04/2011 9:07 pm
RD is sooooo wrong!
shucks i must have imagined the last 14 months of trouble free 1 x 9ing then 🙄
 Tim
Back pedal a 'tiny bit'. Not knowingly either, just setting the pedals - if the chain isnt sat correctly on the bottom run it can come off.
Posted : 14/04/2011 9:09 pm
 GW
[b]GW - I always turn the pedals forward to get them in the right position.[/b]
even while braking? over rough ground? say.. between tight switchbacks with drops? or when leaning over into a turn to your fotward foot side?.. I'd bend pedals axles every ride if I employed your rule.
strictly speaking you should be back pedalling (by tiny amounts) all the way down a rough trail.. and every time you are airborn.. but I know you have no idea what I'm on about here 🙄
RD - aw Shucks indeed.. read that ^^ too
Aaarggg !! It's my own fault, I did ask 😉
Posted : 14/04/2011 9:36 pm
I really don't get why pedalling backwards is easier / better than pedalling forwards to get eh pedals in the right position.
Oh - and you did ask
Posted : 14/04/2011 9:38 pm
 GW
FFS ! Read what i wrote again then
Posted : 14/04/2011 9:40 pm
You say what not why
Half rotation forward or back - wahts the differnce?
Posted : 14/04/2011 9:47 pm
 GW
do you get it yet?
if not, tomorrow (on your commute?) find a grippy corner you can really lean into that turns whichever side your forward foot is and try switching your feet by pedalling forwards as you lean in... go on, I dare you!!
Ps. it's also much faster to drop your outside foot by pedalling backwards through tight successive corners.
No problem - tight chain, good chainline and short cage
Posted : 14/04/2011 9:48 pm
To drop your trailing foot through a corner, you either pedal forward 3/4 turn, or backward 1/4 turn. The latter is three times faster and better. But you risk unhooking the chain if it's rough enough to bounce the derailler around. It's normally ok if it stays hooked on at the top of the chainring as it goes straight back on when you pedal forward again.
I tried with no guide on my XC bike but it would unhook fairly often. A 50g top guide has solved the problem. You might get away with it on a road bike. I reckon the tight chain on a short cage might be the key.
Posted : 14/04/2011 9:52 pm
 GW
it's way faster than 3X.
I happily ride switch so it's always massively faster both ways.
Posted : 14/04/2011 10:00 pm
I should practise switch until it feels natural. I see the advantage. I'm lazy 😉
Posted : 14/04/2011 10:06 pm
 GW
entirely upto you..
pretty much no top Professional DHers ride switch (not when racing anyway). make of that what you will 8)
Posted : 14/04/2011 10:14 pm
 spw3
I set my Ragley 1x9. It works well nowmbut itmtook a while and some v ery frustrating rides to get it sorted.
Various set ups I have tried:
11-34t cassette and RaceFace 32t chainring: fail
11-34t and Surly non-ramped chainring: fail
11-34t and Surly chainring plus Jump-Stop: qualified success.
It now drops it's chain off the inside of the top of the chainring about as frequently as my other (FS bikes with bashring) bikes.
With a 12-36 9 speed cassette it's great.
Posted : 14/04/2011 10:25 pm
36t blackspire unramped front with a Blackspire Ring God, 12-36 rear cassette, long cage xt mech, tight-ish chain and it barely drops. Thats off road on some very rocky trails paing little attention to what gear I'm in.
Posted : 15/04/2011 1:06 am
GW, the op is using 1 x 9 on a CX bike not a DH one, he's not doing drops between switchbacks or trying to bend axles etc, I think you've got the wrong end of the stick here
Posted : 15/04/2011 4:04 am
IME of 1x9 .. using a shortened chain AND a long-toothed, unramped chain-ring ... I would still lose the chain frequently.
Not saying it can't be done, but you'll need to get lucky setting it up .. and bear in mind it only takes 1 drop to scar the heck out of your cranks or chainstay - I speak from experience!
Posted : 15/04/2011 4:36 am
Almost the same setup as bonesetter here, (XT short mech rather than SRAM)
Very, very occasional chain dropping, certainly not enough to be a nuisance.
Posted : 15/04/2011 6:34 am
Oh, forgot to say, I also use a BB which can be adjusted laterally and then fixed which allows tweaking of chainline, so if chain's dropping in, move chianring in and visa versa. This makes for zero dropping off
Posted : 15/04/2011 7:51 am
My only 1 ring set up was always dropping off! Frequently, when shifting up (to a smaller sprocket) the movement sets up a "ripple" along the chain which would drop it straight off the ring - really annoying! Sorted with this.......
Which is now surplus and for sale 😀
Posted : 15/04/2011 7:53 am
 Tim
Its when you lose the chain and kneecap youself on the shifter/stem
then a chainguide is worth it 🙂
Posted : 16/04/2011 8:02 pm
You can all roll your eyes now. I'm going double or tripple 😳
Posted : 16/04/2011 8:05 pm
If people who claim that their chain doesn't ever come off riding off road on a 1x9 set up, without a chain device, knew that what they were ostensibly saying was that they are basically really slow off road, I suspect they wouldn't be so quick to make their point.
Posted : 16/04/2011 8:13 pm
rubbish, some of us can just set up a bike properly
oldgit...triple??? 😯
Posted : 16/04/2011 9:05 pm
Well double then 😕
Posted : 16/04/2011 9:21 pm
I have a bash guard and an N Gear Jump stop - works for me.
Posted : 17/04/2011 5:26 am
for CX all purpose bike, i'd go normal CX crank and rings, mtb cassette with long cage rear mech, plenty of gears there
Posted : 17/04/2011 6:56 am
Don't use one as we run out of stock before I get a chance to fit one
Short chain
White industries single speed ring
Mech wound back a bit
Chain has come off once on long dh.
Will fit a mrp bb mounted device one day.
Posted : 17/04/2011 7:09 am
Oh hang on you're being serious aren't you.
Posted : 17/04/2011 7:16 am
Built up a new bike Friday night, and had to change the chain device as my LG1 wouldn't fit. Couldn't get the chainring bolts out, so had to bodge a gamut device without the bash plate for yesterday's ride. See here:
Tight chain, short mech, unramped chainring - pretty much all the rules described in this thread. Still lost the chain once when going fast through a a rooty section at Woburn. Without a proper device i1x9 is no good for anything other than bridleway riding.
I'm pretty sure the chain would have stayed on if I was jumping of a 10" bit of tarmac in the high street though.
Posted : 17/04/2011 7:58 am
geetee1972 - Member
just relating the facts, i.e. you [b]can't[/b] stop the chain dropping on 1 x 9 (assuming you have tried it and are not basing your "facts" on something you've heard or dreamt up) and i [b]can[/b] stop the chain dropping with simple set up
Posted : 17/04/2011 9:00 am
14 months and you havent had the chain come off the lower part of the chainring and gradually roll off the ring as you descend a rough trail?
Take that bike up here and even the tame stuff will have it off in an hour.
Its when you descend and stop pedalling that it will hop over the teeth at the bottom.. then work its way off.Sometimes its possible to pedal it back on but depending on how long and rough that track is.. you will lose it.
14 months?
14 freekin months?!
:::walks off muttering fourteen months shaking his head with a frown:::
Posted : 17/04/2011 9:42 am
the chain might not come off without one and with the correct set up, but I would rather ride with confidence knowing it's not going to come off rather than worrying that it might
I have an e13 XCX which weighs about 70g
Posted : 17/04/2011 11:06 am
rOcKeTdOg - Member
why put an ugly [u]heavy device[/u] on and just carry it around when it's not needed?
Strange point to make when you ride with a long cage mech. 😆
Posted : 17/04/2011 12:40 pm
