1X11 M8000 - 32T Ch...
[Closed] 1X11 M8000 - 32T Chainring Vitus Sentier VRX 2017
6 Users
As i only use bike on flat trail, road with few hills i find
i need more speed. What is the best chain ring to replace 32t shimano xt
on Vitus Sentier VRX please. Help gratefully appreciated.
Posted : 01/01/2018 9:58 pm
Put a 36t on if the bike takes it, most do, but worth a check. There are loads of aftermarket makes for the m8000, which is 96bcd, uberbike component do one I think, I think they also do a boost or non boost version depending on your rear end. Others are wolftooth and one up, or absolute black if you fancy a flash oval job.
Posted : 01/01/2018 11:07 pm
Following this with interest.
I spin out trying to keep up with mates with a 32 tooth, so I was thinking about stepping up to 34, but was wondering about a 36t oval instead.
LittleMissMC could inherit the 32t ring, if she rode a bit more her 30t would be redundant
Posted : 02/01/2018 7:41 am
An oval won’t give you less spin out at speed it just helps remove some of the dead spot in the pedal stroke, mainly when climbing.
The only other option is to change cassette and go to a Sram 10-42 or similar or even an e13 9-42. Both would require an Xd driver body on the hub. That drop of 1 or 2 teeth does make a difference, but after personal experience I question the longevity of the e13 cassette.
Posted : 02/01/2018 7:58 am
Stick with the Shimano one, I find them really good and they last forever.
Personally I don't get this spinning out on a 32t, on a 29er 32/11 at 90rpm is 22.5mph and 100rpm it's 25mph.
Posted : 02/01/2018 8:42 am
Some of us go faster than 30, and still expect the pedals to have a useful purpose. 35mph = 150rpm, which is officially ragging it.
I use absolute black 32 oval, and spin out well before top speed. That's why I use 3x9 on the other bike. No idea it that (or 34, 36) would fit the bike in the OP though.
Posted : 02/01/2018 10:38 am
I've been using a Works Components RF Cinch 32t Oval on my 1×11 Whyte T130 RS for the last 6 months ..and it works brilliantly ..
Liked the idea of supporting a small British company and at half the cost of Absolute Black ..why pay more ..
Also happy to dispense advice where needed on the phone ..
http://www.workscomponents.co.uk/works-components-32t-oval-narrow-wide-chainring---104bcd-fitment-870-p.asp
Posted : 02/01/2018 12:09 pm
