1x10 or 1x9? Option...
[Closed] 1x10 or 1x9? Options and opinions...
5 Users
I'm about to convert my Genesis Fortitude SS to 1x9 or 1x10 setup. I'd like to use Problem Solvers Mech Hanger.
- Is it worth to use 1x9? It's cheaper and I'll miss only the 36t cog...
- Is there any option to avoid chain keepers? (Any other than SRAM XX1... 🙂 )If there isn't which chain keeper do you recommend for XC/marathon?
- Which derailleur and why? Shimano Zee? XT? Sram?
Thanks in advance!
Posted : 07/10/2014 5:28 pm
I would recommend 1x10. Better gear range so less compromised ratios and have simple option of adding 40T big sprocket too. Narrow wides are best at retaining chain!
Posted : 07/10/2014 5:44 pm
Also, what are you doing about cable guides?
Posted : 07/10/2014 5:45 pm
Go 1x10, that way you can use a clutch mech which, combined with a n/w c/ring, will give you all the chain retention benefits of XX1
Plus, 10 is 1 betterer than 9.
Posted : 07/10/2014 5:50 pm
[b]jamj1974[/b] -
I think I'd use full-length cable house...
[b]tomhoward[/b] -
What is your suggestion?
Posted : 07/10/2014 5:58 pm
I ran 1x9 for ages. I used a 12-36 cassette so only missed the 11 tooth of the 10 speed. In Wales this was the better way round I think! I now run 1x10 but use an 11-42 cassette.
Posted : 07/10/2014 6:04 pm
tbh the clutches work as well as each other, so it's down to personal preference on the way they shift. I use SRAM (as im 1x11) but have ridden Shimano and prefer the action of SRAM (slightly more weight to it than Shimano)
So pick a side, then the model that suits your budget really!
Edit, on the C/ring, ive had no issues with the sram x-sync that came with my cranks (not sure about after market availabilty for other mfrs cranks though?) and a raceface N/W. (this includes a 2 weeks dh holiday and I've never dropped a chain using either of them)
Posted : 07/10/2014 6:10 pm
[b]tomhoward [/b] -
I have a complete 2x9 setup with XO gripshifter and XO rear mech with medium cage . Is that possible to use the mech in a 10speed system... ?
Posted : 07/10/2014 6:22 pm
Not sure but I have my doubts. I'll have to defer to others on that on. Though you still wouldn't have the clutch if you used it.
Posted : 07/10/2014 6:49 pm
No to using 9 speed Sram with a 10 speed system. You can use any front mech with your left hand shifter but the rear mech and right hand shifter are specific for 9 speed and will only work with SRAM stuff too.
Posted : 07/10/2014 7:01 pm
But you can use a 10 speed Shimano clutch mech with your 9 speed SRAM shifter, as luck would have it they work 😉
Posted : 07/10/2014 7:22 pm
[b]iffoverload[/b] -
Okay... but why should i do this? 🙂 I've 9spd mech. 😀
Posted : 07/10/2014 8:16 pm
OK, thought you were interested in a clutch mech, you mentioned avoiding chain devices in your OP,
your 9 speed cass and shifter would work with it so its a cheap way to get it and if you go decide to go 10 sp later (when your cassette is worn out) you only need a shifter.
Posted : 07/10/2014 8:34 pm
I think I got some fairly neat M-Part self adhesive cable guides for full outer runs and they have worked fine for my dropper cable.
Posted : 07/10/2014 8:39 pm
Oh, I've just realised the advantages of 'clutch mech"... 🙂
Does I need a 10spd Shimano clutch mech to work with 9spd SRAM shifter?
Posted : 07/10/2014 8:50 pm
Yes, but Iirc it's not plug and play, you'll need to fashion a 6mm spacer for the mech, to deal with the cable pull I think. There's threads about it on here, and elsewere on the web.
Posted : 07/10/2014 9:09 pm
here you go
http://www.pinkbike.com/forum/listcomments/?threadid=148662
I have tried it with and without, there is not a big difference
Posted : 07/10/2014 9:23 pm
