1x10 in Calderdale ...
[Closed] 1x10 in Calderdale area…….
25 Users
hello,
i currently have a 3x9 set up and was wondering about 1x10?
i have been riding almost 2 years and live in the calderdale area.
just after some real life experience from other people that ride in this area……
Any thoughts would be great, cheers.
Posted : 26/01/2017 4:19 pm
How strong are your legs and do you mind pushing?
I've run 1x10 on rides around calderdale (32x40t lowest gear) and could grind up a lot of stuff, but then my ego allows me to push if it's too hard
Posted : 26/01/2017 4:40 pm
nah, i don't mind getting off to push from time time.
but you got me thinking, perhaps i should work on legs first then the bike.
plan for the long game and think about the change once i improve strength and stamina.
cheers for reply
Posted : 26/01/2017 5:09 pm
How good a climber are you anyway?
I've been OK on 1x10 there, but 1x11 is a little bit nicer (with 42t rather than 40t biggest sprocket).
Posted : 26/01/2017 5:24 pm
Best way to work on them legs is on your bike so get it done.
Go 1x11 if you can. 42 or 46t on the back and a 30 or 32t on the front. You'll be fine, I did it.
Posted : 26/01/2017 5:37 pm
I used to run 1x9 around here for years, waaaay before the advent of 30t chainrings and expander cogs. Run 1x11 now with low gears but never not been able to get up anything that I would do on a bike with 27 gears etc. Just in the process of building another singlespeed too - if you want to brutalise yourself, get rid of all your gears! (although I may relent and put 1x11 on it as well).
im fat and very unfit.
i push a lot.
its ok but i find it very hard work. comming from 3x9 youll be fine.
 dale
Trying 1x10 round here at the moment (came on a bike I bought) 30x40 its ok but i miss my granny ! you can get up most stuff with a bit of gurning (penny steps still taunts me)but after 20 miles I begin to think about 2x10 and its sit down and enjoy the scenery gearing !
Posted : 26/01/2017 7:11 pm
 NCC
I ran 1x10 for a couple of years on my old Five. 30x42 if I remember rightly. I don't think I ever really missed the previous 3x9 and it was ridden just about everywhere round here.
So entirely doable, even for averagely fit old blokes....
Posted : 26/01/2017 7:36 pm
What you need to do - ignoring all the gumph about extended range rear cassettes - is to have a kick down bailout granny gear.
Both my bikes with 1x10 have it on, and it means that you can run a narrow/wide ring up front with a standard 11-36 cassette out back. If you get tired, or the hill is too steep, just nudge the chain over with your heel. Job jobbed. Top of the hill you stop for a breather, and put the chain back on the bigger ring.
Hardly ever used, and I ride around some steep stuff in Devon and on Dartmoor, but it's good to have as a last resort.
As seen here on my Bolt.....(yeah I know that back patio is a mess, it's winter!)
[url= https://c1.staticflickr.com/1/264/31653980113_d55abed0ba_h.jp g" target="_blank">https://c1.staticflickr.com/1/264/31653980113_d55abed0ba_h.jp g"/> [/img][/url]
Posted : 26/01/2017 7:43 pm
32f 11-40r on FS & 30f 11-42r on fatbike, no issues 99% of the time, happy to push the rest.
I have left the granny ring in place for the rare long climb, only used it up in the lakes occasionally.
Posted : 26/01/2017 7:52 pm
I would caution against it. You will have fewer gears.
Posted : 26/01/2017 8:02 pm
cheers guys
good to hear from people who have been converted!
as an average fit guy it sounds do-able and if i keep to granny ring as a back up sort of kick down gear until i'm comfortable.
or maybe i could get another bike. always a winner!!
Posted : 26/01/2017 9:15 pm
Shirley the Peckett well or Blue Pig descents are worth that bit of thigh muscle sacrifice ?
The tarmac climb up to the PBW New Rd to Horsehold road is a good training route.
Posted : 26/01/2017 10:59 pm
I live there (top of blue pig) and distinctly average, I'm on 1x11 with a 40t top and it's all pretty doable
Posted : 26/01/2017 11:13 pm
Just fit a suitable extender cog. If you're worried about fitness, then you sure as heck won't care that you loose a bit of top pedaling speed, because the last thing an unfit person can do is pedal a heavy, draggy, aerodynamic brick of an MTB at over 15mph for more than a minute or so!
Fit a 30T front ring with a 46 (or even 50) tooth extender and ride up everything!
Just out of interest, has anyone climbed Shoebroad Lane, behind the old Unitarian Church in Tod?
Only walked it and driven it, but always wondered if it'd go.
Posted : 26/01/2017 11:22 pm
 marc
I'm in Calderdale too, easy gear is 32x42 on 26" wheels.
I wouldn't go lower myself.
Posted : 27/01/2017 11:56 am
A Strava segment search shows it as a descent but not an ascent. If you've driven it then presumably it should be doable, unless by "drive" you meant in a 4x4 or ridden on a trails bike.
Posted : 27/01/2017 12:35 pm
Hebden based, both main bikes have one gear, 32/20. CX bike 42 with 12-36 rear. Few things I can't ride up, but that took a while to get there. Fitness and less weight are your friend.
[url= https://c1.staticflickr.com/8/7682/17061270610_1c540dbcea_b.jp g" target="_blank">https://c1.staticflickr.com/8/7682/17061270610_1c540dbcea_b.jp g"/> [/img][/url][url= https://flic.kr/p/rZDtm7 ]Sunny Salsa[/url] by [url= https://www.flickr.com/photos/13995637@N08/ ]Greg.May[/url], on Flickr
Posted : 27/01/2017 12:36 pm
Rusty Spanner - Member
Yes. It's not that bad if you take the turns on the less steep outer side. Climb up to the Packhorse at Widdop by the scout hut is worse.
Also, if you've not tried some of the uber steep roads up to Great Rock/Bridestones area...well, you're in for a treat 🙂
Also - the segment is called " Honey Hole Rd to Lumbutts Rd "
Posted : 27/01/2017 12:37 pm
Greg - do you mean [url= http://www.streetmap.co.uk/map.srf?X=395243&Y=430894&A=Y&Z=115&ax=395771&ay=431439 ]this bit of road[/url]?
Posted : 27/01/2017 12:42 pm
whitestone - Member
Greg - do you mean this bit of road?
I do, for some reason it wipes me out more than the other piece. Suspect as it's normally part of a longer ride, and the few "bumps" before it are a bit tiring SS.
Posted : 27/01/2017 12:45 pm
 nach
It's doable on 32-42 but you'll probably be stamping up the Honey Hole section. Was with DazH the other week and he did it on a single speed…
Posted : 27/01/2017 12:46 pm
Singlespeed? 😯
Only done it a couple of times in that direction - I normally do the Colne-Widdop-Hebden loop the opposite way but then you've got [url= http://streetmap.co.uk/map.srf?X=390842&Y=434508&A=Y&Z=115 ]this[/url]!
I don't find that bit below the Packhorse as bad as [url= http://streetmap.co.uk/map.srf?X=398469&Y=426927&A=Y&Z=115 ]this road[/url]. But when we are doing that we've done all of 400 metres from the car park as warm up 🙄
Mind you some gradients are just "wrong" even if they aren't *that* steep. I still haven't done Mythom Steeps! Surely it can't be as bad as Thwaites Brow in Keighley. Can it?
Posted : 27/01/2017 12:51 pm
Mythom Steeps!
It's a funny one - very close to my house so I'm usually fresh riding it and have zero issues on it SS. But, it does take quite a bit of grunt.
There is a climb hidden in behind Cross Stones Road that I was shown once by TimK on a ride that was nuts - not for it's gradient persay, but more the continual length and gradient combined. Must go find it again.
Posted : 27/01/2017 12:53 pm
 nach
[url= https://www.strava.com/segments/6645128 ]Hey Head Lane[/url] by any chance?
whitestone - Member
Singlespeed?
I suspect it was no longer in the 36-36 configuration from last spring 😀
Posted : 27/01/2017 1:18 pm
 dazh
Singlespeed?
It was a close run thing. 32-20 gear and I nearly gave myself a hernia 🙂
The real scary one is Doghouse Lane behind the station. Haven't plucked up the courage to try that one yet.
Posted : 27/01/2017 1:40 pm
 Chew
The Mythom bit is ok, its just when your legs a feeling it then kicks up again up Ratenstall Bank.
We wont mention Trooper Lane.....
1x10 30/42 is fine around Calderdale you'll just need to get on with it rather than spinning away.
Posted : 27/01/2017 1:46 pm
Trooper Lane - is that tarmac or cobbles/setts? There are all those short steep things around Calderdale in the 100 climbs book that I've not done.
How about [url= https://www.strava.com/segments/1160343 ]The Buttress[/url]?
Posted : 27/01/2017 1:55 pm
 dazh
Buttress is fine on 1x10. The problem is more one of grip than the gear. Not tried it on a singlespeed yet. Will be doing Trooper Lane on Sunday as I"m showing someone the Calder cobbles as a prep for Flanders.
No one's mentioned Penny Steps yet which is surprising.
Posted : 27/01/2017 2:27 pm
I ride 1 x 10 in the Calderdale area a lot. Pennine way, pennine bridleway, Stoodley Pike, Warland, Gaddins Dam, Blackstone Edge, Langfield Common, Watergrove, Hades Hill, etc.
Do wheel sizes effect gearing my lowest gear is (I think) 30 x 42.
When its steep, It feels hard. It feels like when my gears wear out, I need to replace them with a smaller chain ring.
Is 30 x 42 on a 29er the same as 30 x 42 on a 650B or even a 26 inch wheel size?
Posted : 27/01/2017 2:33 pm
Yes, wheel sizes affect gearing.
Assuming that you keep the same cassette then the following are roughly equivalent:
26" wheel & 34T chainring
650b wheel & 32T chainring
29" wheel & 30T chainring
@dazh - might be worth a go on the crosser then! I'll wait until after a dry spell though and before the trees come into leaf.
Posted : 27/01/2017 2:36 pm
Ok thanks
I think I'm going to get a 26T or a 28T chainring then next time I replace my gears. I find that I'm struggling at the low end a lot, but never running out of gears at the top end.
Posted : 27/01/2017 2:40 pm
 Chew
The easy bits tarmac, then it gets steeper and cobbled 😉
Shout up if you want a day around Calderdale and we can pick up some of the classics.
Not sure i'd use it for training, unless thats walking.......
Posted : 27/01/2017 2:43 pm
 dazh
Not done the buttress on the cross bike either I must admit. Last time I did it was on a 650b+ with a 34-36 gear. Still hard obviously, anything with a 35% gradient will be, but it's doable. Also the top section is the slippy bit, just when your legs are screaming and your lungs bursting you need to concentrate to keep the back wheel weighted to stop it slipping.
Posted : 27/01/2017 2:44 pm
If you go that low then you won't fit those chainrings on a 104BCD spider, you'll need to go direct mount as the mounting pins will foul the chain. An oval chainring helps with climbing IME, smooths out the pedal stroke. A bit easier on the knees as well.
I struggled a bit when I first got a 1x10 drivetrain but after about three months I got used to it. If I can't get up something now it's invariably something that even on 3x10 I wouldn't be able to do it. I ride with either 30T or 32T up front with an 11-40 cassette (standard XT cassette with 40T extender), it's not often I'm in the 40T.
dazh - Member
Singlespeed?
Man up Daz. It's not _that_ bad....
Buttress is fine if it is dry.
Posted : 27/01/2017 3:02 pm
Greg, it's that "if it's dry" bit that worries me! Every time I've ridden past and looked at it even the bottom bit is damp and greasy.
Posted : 27/01/2017 3:04 pm
i've just gone from a 3x10 on my short travel full suss [lowest gear was 22t/36t (0.61) far too low]. to a 34t / 46T (0.74), damn crook on ebay said it was a 32T chainring. but i did 65km and 1350metres last saturday and found the 34T with the bigger cog adequate..
i'm doing the rochdale rideit tomorrow which will prove if its right for me.
on a bigger suspension bike 140mm/150mm i find the 30T / 42T (11 speed) is the highest chainring i can go for the big hills, but the topend gearing is plenty (30/10 = 3.0). where i'd say you need around a 3x if you ride some road sections.
it all depends on your fitness, weight, bike (hardtail < > big suspension) wheel size, and prefered cadence
one thing i'll say if going xt m8000 11 speed, the jump from 46T granny to the next gear 37T is massive and i didnt like it, but all the other gears felt amazing..
not been to calderdale in a few months, so think i'll get the train over next saturday.. ;0)
Posted : 27/01/2017 5:00 pm
 dazh
Man up Daz
Indeed. Could be a fun(?) idea to do them all in one ride. Starting in Hebden or Tod...
The Buttress/Heptonstall
Horsehold Road
Penny Steps
Honeyhole lane
Inchfield Road
Pexwood/Stones Road
Doghouse Lane
Jumps Lane
Cross Stone Road/Hey Head Lane
Mytholm Steeps
And all linked by offroad descents.
So who's in? 🙂
Posted : 27/01/2017 5:47 pm
Might be type 2 fun. Isn't there an annual ride that does most of the Calderdale Cobbled climbs?
Posted : 27/01/2017 6:03 pm
 dazh
Yeah the Ronde Van Calderdale. Always thought that was a bit of an odd [url= https://www.strava.com/routes/2059209?hl=en-GB ]route[/url] though. [url= http://thehelloftheworth.blogspot.co.uk/p/2015-route.html ]The Hell of the Worth[/url] is a better route IMO, and it includes the buttress which the RvC omits.
Posted : 27/01/2017 6:59 pm
The Hell of the Worth looks >ahem>worthwhile</ahem>. Might be a bit much at this time of year.
Technically they aren't cobbles but [url= https://en.wikipedia.org/wiki/Sett_(paving) ]setts[/url]: cobbles are random stones from streams and rivers; setts are dressed stone from quarries and uniform in size/shape.
Posted : 27/01/2017 7:26 pm
Every days a school day, thanks Whitestone.
Posted : 27/01/2017 7:41 pm
My lowest gear on my 1x10 is too high, it doesn't seem stop me riding up anything particularly steep that I couldn't do previously, but I get tired more quickly than before, because previously, there was always a "very easy" gear to go back to take it easy for a moment on a steep hill, while now, its more 'full on' effort all the way.
Posted : 30/01/2017 12:19 am
dazh - Member
Horsehold Road
Penny Steps
Honeyhole lane
Inchfield Road
Pexwood/Stones Road
Doghouse Lane
Jumps Lane
Mytholm Steeps
So who's in?
You forgot Eastwood Lane.
And no, no I'm not in.
Posted : 30/01/2017 12:45 am
Grannyjone definately agree I got a 32t/42t on an enduro bike and it absolutely annihilated me on regular trails, changed that to a 30t chainring and it's a far better ride,
Just gone 34/46 on my short travel Fs and it rode like a dream on the Rochdale ride it, the 250m climb up to the rams head inn from under the m62 near the littleborough rugby club went far better than I expected, the previous year I nearly died up it..
it was just about low enough to grind out the steepest sections.
Posted : 30/01/2017 6:17 am
Daz - sounds stupid, I'll join in.
Posted : 30/01/2017 9:51 am
 dazh
Greg I think I may go and do some of that route this weekend if you're free and your leg has healed enough. Doubt I'd manage them all on a singlespeed but you never know.
Went and did the Halifax cobbles yesterday. Trooper lane is somewhat character building 🙂
[img] ?oh=e9d9c8da47201d453bdcabbf42cc8879&oe=590F2538[/img]
Posted : 30/01/2017 1:07 pm
 Chew
Top marks for Trooper Lane on the road bikes.
Can imagine it was very greasy. I only just managed it with something with plenty more gears........
Posted : 30/01/2017 1:53 pm
That's partly what I was thinking especially after the dreich day on Saturday.
I reckon April's a good time for the cobbles as you have the chance of a decent spell of dry weather and the trees aren't in leaf so things have a chance of drying out.
Dunno what's going on, maybe the mild winter, but I've been spinning out on tarmac climbs recently and not steep ones either. There just seems to be a lot of muck/grunge on the roads at the moment.
Posted : 30/01/2017 2:10 pm
 wl
Depends where exactly you ride in Calderdale and how determined you are not to have to push. There are some long and very steep/technical climbs that need very low gears unless you're superhuman. Also, if you do long rides and still want to climb those climbs 5 hours in, you'll really need those easy gears. Crap trails conditions for much of the year just makes it harder.
Posted : 30/01/2017 2:39 pm
 core
I've just put a 22t bail out ring back on my 1x10 zesty, I've been finding towards the end of rides I'm too knackered to push the 32/42 on proper hills. No front mech though, I'll just switch over manually if I need it. The ring itself weighs hardly anything, even with bolts, and you can't really see it.
#stealthgranny
Posted : 30/01/2017 2:46 pm
 dazh
Trooper Lane was bone dry. Shibden wall a bit damper, and Gibb Lane covered in crap as usual. All do-able on compact roadie gearing as long as you keep your arse on the saddle do a bit of grunting.
Posted : 30/01/2017 4:39 pm
looks like some awesome climbing to be had out there. think i will have to seek them out and give them a go on the 3x 9 and see how i get on.
should give me some food for thought
Posted : 08/02/2017 8:38 pm
