1x10 cyclocross dri...
[Closed] 1x10 cyclocross drivetrain help
15 Users
My CAADX needs some tlc ahead of the upcoming season, so going to go 1x10 on the drivetrain. Is there a clutch mech out there that will work with a tiagra STI shifter?
If there isn't, will a normal road mech and a narrow-wide chainring do the business in a CX race?
Posted : 01/08/2016 10:12 am
I run a normal mech and a NW ring, with a Hope chainguide and it never drops a chain. For me, this is a better solution than a clutch setup.
The only mechs that have clutches are MTB, which have a different cable pull to road STI.
Posted : 01/08/2016 10:19 am
I run a 38t Superstar I/O ring, a 11-32 SLX 10 speed cassette, 105 10 speed shifters & 105 CX ear mech, get the chain short enough, but not too short. Quite a common set up in the NW league (models may vary)
I haven't dropped a chain yet while racing or battering around on trails.
You can run a Shimano clutch mech with road shifters if you use a Lindarets Tanpan, but to be honest, with a short mech & chain it's not really necessary for racing.
Posted : 01/08/2016 10:22 am
No
I've been using a normal road mech with a nice short chain and the B tension up for the last year and never dropped the chain (38 wolf tooth front, 11-40 rear)
I don't race* but ride some pretty rough trails
Gevenalle do a 10 speed shifter that does work with an MTB clutch mech
*well I did once, I sucked
 D0NK
42 + 10spd 11-36 here, chainguide and standard rings/mech, pretty sure I've never dropped a chain, I really like it. If you're racing you may want to drop the F ring size a bit, but for normal riding there's still top end speed for road sections and I've not felt over geared on any [i]rideable*[/i] xc climbs.
*ie one I can get up on my mtb with lower gears.
Edit - I ran a 9spd slx shadow mech originally, worked perfect, couldn't find one when I replaced the drivechain recently, got a long cage 10spd 105 on there currently, bit clunky getting into biggest sprocket but it does work.
Posted : 01/08/2016 10:46 am
Thanks all - simple road mech and a narrow wide sounds like the place to start.
Posted : 01/08/2016 12:04 pm
Worked for me. Now upgraded to 11sp hydros and using a tanpan with a zee rear mech and 10s 11-36, eventual plan to go to 11-40 11s.
Posted : 01/08/2016 12:28 pm
A NW chainring makes most difference IMO.
My cranks bit the dust earlier this year and I was doing an event the next day so used the triple chainset and cranks off my wife's bike -dropped the chain a couple of times (clutch mech in off position) and once with clutch on.
I've yet to drop the chain using a NW chainring with clutch on or off.
Posted : 01/08/2016 12:51 pm
 tang
Yes.
Use the Lindarets Wolftooth tanpan and run a shimano clutch mech. Or just a 'road link' to extend the cassette range on a short road mech. I've done both and both work.
Posted : 01/08/2016 1:22 pm
You can always move the cage spring to the stiffer setting on a regular shimano road mech to help as well
Posted : 01/08/2016 1:33 pm
whats this road link thing? does that mean I can get a range similar to an mtb cassette with a road cassette using a road shifter?
Posted : 01/08/2016 1:58 pm
 tang
It means you can run a mtb cassette (I've run 11-36 and 11-40 on a ss 105 mech) with a road mech. The advantage of the tanpan is the use of a clutch as big cassettes on short mechs is a bit slappy on high gears.
Posted : 01/08/2016 2:22 pm
I ran normal Shimano road mech with the cage spring on the stiffer setting and a n/w ring up front last season and had no issues at all.
Posted : 01/08/2016 3:42 pm
I'm just about to setup my tripster in CX race mode with 1x11. Bought some 2nd hand ultegra cranks and a 34t superstar NW chainring..
How do you change the cage spring setting?
Posted : 01/08/2016 6:11 pm
My crosser gets ragged round mtb trails with NW and short cage 105 mech, not dropped a chain yet
Posted : 01/08/2016 6:12 pm
 cp
See step 7 :-
http://www.parktool.com/blog/repair-help/rear-derailleur-overhaul#article-section-3
Posted : 01/08/2016 6:14 pm
Thanks
Posted : 01/08/2016 6:18 pm
A rival 10 speed shifter and an x9 clutch mech will also work. Bit more spendy than changing the tension spring though
Posted : 01/08/2016 7:26 pm
