1x 11 setup on a ne...
[Closed] 1x 11 setup on a new style BFe
7 Users
Having an issue getting the 1x11 set up on my BFe. I bought an XT build kit from Merlin cycles - my first foray into 1x11 but previously I briefly ran the same frame as 1x9 with no issues - this on a standard XT double chainrin with no front mech.
Trouble is the chain drops off on the inside of the front ring when I try to shift up to the biggest two gears on the back. Seems like a chainline issue? I am not running a chain guide - but I shouldn't need one with a clutch mech and a narrow/wide chainring?
I have tried to improve the chain line by shifting the BB spacer to the non drive side which I think made a marginal difference but not enough.
Posted : 02/01/2017 8:56 am
it's more likely to be the limit screw on the derailleur
Posted : 02/01/2017 9:17 am
The chainline using a double chainset with the T/T ring in granny position is wider than that of a triple chainset with the TT ring in the middle position. Get some 2-3mm chainring spacers and move the ring inwards.
Moving BB spacers around does the same thing, but also moves your pedals over too which I'd avoid.
Posted : 02/01/2017 9:18 am
I'm running 11sp on mine without issue. I've got an XT triple running a narrow wide on the middle ring with one BB spacer on the drive side. I found 11sp more sensitive to setup than 9sp and 10sp, so I'd check the limit screw and make sure the mech is aligned before fitting chain...
Posted : 02/01/2017 9:55 am
I run xt triple with RF NW and xt 11 speed it really is sensitive to set up cable tension seems to be critical.
Just built up a new bike with a full xt group set with the new xt cranks set up was slightly easier. Not ridden it yet.
Posted : 02/01/2017 10:01 am
As above, space the chainring in 2mm.
Posted : 02/01/2017 10:08 am
Are you shurethey didnt supply a boost chainring for your cranks? That would make alot of difference.
Posted : 02/01/2017 11:44 am
Thanks eill check derailleur setup and get some spacers.
What is a boost chainring?
Posted : 02/01/2017 12:27 pm
