Bike Forum
3
Posts
4
Users
0
Reactions
36
Views
I understand that Fox 36 forks take a 180mm rotor with no adapter needed, how are they with a 183mm Hope rotor?. Also if I went 203mm for any reason would an H adapter with caliper work?. Thanks in advance.
Posted : 26/03/2019 8:46 pm
Can’t help you with the first question but for a 203mm rotor the H mount is what you need
Posted : 28/03/2019 7:10 am
Depends on your rotor if it will work ok, if not put a washer under each end of the cailper (one between 1 - 2mm.
Posted : 28/03/2019 7:44 am
H mount for a 203 didn’t work for me. Could have added washers but swapped out for a 200.
Posted : 28/03/2019 8:30 am
