183 HOPE FLOATING R...
[Closed] 183 HOPE FLOATING ROTOR, WITH FORMULA ORO K18
2 Users
Is it possible to run a Hope floating rotor 183mm with my existing set up of Formula ORO K18 180MM caliper and mount.?
Posted : 31/03/2012 5:41 pm
i'm not sure if you can use a few spacers for the mount, however I can tell you from exp that even with the correct mount the rotor wont fit in your caliper. The raised bolts on the rotor are the problem.
I had the issue with my k18s, tried to realign, so did the bike shop. Didn't work.
Posted : 31/03/2012 5:49 pm
