As title. I've heard the 16mm chains are very heavy and could damage bikes?
16
Thats around the point where normal bolt croppers stop being able to cut the chain. 13 mm can be cut
Been using a 19mm Almax for a number of years, on my collection & yet to damage anything with it.
Yep Almax for me too. Two of them for my motorbikes. The MTB stays in the kitchen so not needed
Both of mine were stolen from first floor bedroom / office. So yes there is a need.
I'll go 16mm then - thanks.
16 mm will require an angle grinder and your frame still needs just a hacksaw
Personlly it is about general security - delaying and good insurance
I use. some good locks and ground anchors inside but given time you would get them.
That's true. I have a 16mm chain and ground anchor and can confirm from experience that my lovely Brodie Holeshot Ti frame required only a hacksaw. 🙁
I went for 2m of 13mm, on the same frame hacksaw premise.
16mm+ for me on the basis less than that is fairly quickly bolt-croppable. The chains do weigh a lot but you just need to be careful when putting them around the bike(s), more of a hassle the more bikes you have. Obviously not going help if they're prepared to destroy the frame as well but hopefully that's not a common occurrence...
2m enough to ground anchor two bikes?
19mm almax. I still don't sleep well but it helps.
Not sure what you mean by a heavy chain damaging the bikes, mine regularly endure a 200lb weight 😉 but if you are worried about the chain damaging your bikes paint etc., slip an old DH/MX innertube over it
Almax chain here with a massive Squire Stronghold shackle.
I'd rather they had to cut my frame and didn't benefit from it than got the lot in seconds. Most other chains can be cropped with long handled croppers in a heartbeat.
I bought a 3m length of 16mm chain a few years ago and made a sock from an old duvet cover with a sewing machine.
Double thickness polycotton has protected the frames so far, and being indoors on dry frames all is fine.
This ties the collection to a ground anchor and a steel framed workbench.
I use 18mm Krypto Forgetta D-locks on the expensive ones too.
PaulD
To get around the hacksaw problem (well, partially) you could use two 12mm cable loops attached to the chain- one going through front wheel and fork brace, the other through back wheel and chain/seat stays. pita to get through all that.
Yes 12mm cable [i]can[/i] be cropped but not easily and means they'll need angle grinder and croppers and hacksaw
[url] http://www.amazon.co.uk/Sterling-121C-1200mm-Double-Coiling/dp/B001CN0CZM/ref=pd_cp_diy_2 [/url]
Pragmasys chains all come with a protective covering btw
