160MM PIKES Where f...
[Closed] 160MM PIKES Where from
9 Users
So on the lookout in the not too distant future for some 160mm pikes. Wheres the go to place to get them cheap these days?
Posted : 13/11/2015 10:39 am
 LoCo
Wheel size?
Posted : 13/11/2015 10:48 am
Ze Germans.
Posted : 13/11/2015 10:50 am
 LoCo
Posted : 13/11/2015 11:09 am
27.5 although they will be run 26 for the forseable.
Posted : 13/11/2015 12:18 pm
Tick.
Posted : 13/11/2015 12:19 pm
would take 150mm if they were much cheaper
Posted : 13/11/2015 12:21 pm
I bought mine last year from Alltricks for about £320 posted,went for 150 though as another £100 for the 160's,eventually swapped out the air shaft and put them to 160 for 25 quid.
Posted : 13/11/2015 12:49 pm
 LoCo
Drop us a mail
Posted : 13/11/2015 12:51 pm
 Euro
Drop us a mail
All of us??? But i don't have any for sale 😛
Posted : 13/11/2015 1:13 pm
 LoCo
All of us???
Yep I'm lonely 😥
Posted : 13/11/2015 1:14 pm
 LoCo
On another note whether you're buying from us or elsewhere, you really want to go for the 2016 Pikes as they have had a few design changes, most notably the redesign of the damper sealhead and seals which will improve reliability.
Posted : 13/11/2015 2:59 pm
the grey bottomless tokens are different too. They're a little narrower to allow for air to move past the sides for some reason.
Posted : 13/11/2015 3:12 pm
I think they're just that size to fit the Lyriks (which have thicker stanchion walls).
Posted : 13/11/2015 3:16 pm
 LoCo
Red ones are faster though 😉
Posted : 13/11/2015 3:17 pm
Along with the seal head is a new extended rebound shaft/rebound piston mount. The Extended rod is no longer undersized from the rod so it slides in the seal head bushing, its triangulated so it stops above the bushing.
Posted : 13/11/2015 3:39 pm
How do you tell them apart? Are the 2016 the ones with the decals applied at an angle?
Posted : 14/11/2015 5:49 pm
You check the serial number. Ones with 2016 decals are not guaranteed to be 2016 model year forks.
Posted : 14/11/2015 6:30 pm
