160mm cranks? For 5...
160mm cranks? For 5ft2 rider.
11 Users
2 Reactions
Hi,
I'm wondering what 160mm cranks there are put there? I'm struggling to find any. I'm 5ft 11 and moved from 170mm to 165mm and found it to be a nice change my partner is only 5ft2  and using 170mm cranks. She's finding that she's hitting her pedals alot which maybe partly  technique. The BB on her bike is pretty  low though and we ride a lot of trails with rocky technical climbs. I'm thinking it might make more sense for her to get 160mm cranks instead of 165. Any suggestions?
Posted : 13/01/2024 10:19 pm
I have used these on my children's and wife's bikes - https://www.sourcebmx.com/products/jet-bmx-square-taper-race-cranks?variant=31801814974575
Going with these on my son's new bike - https://www.aliexpress.com/item/1005006018474460.html?spm=a2g0o.order_list.order_list_main.10.2db818024UziCJ
I am using with a Shimano BB - you have to trim the end of the axle down or use an axle spacer.
Posted : 13/01/2024 10:23 pm
I found some 155mm SRAM GXP cranks when I was building my son's bike. Will see if I can find them online.
Edit these: https://fawkes-cycles.co.uk/sram-nx-gxp-crankset-155mm-32-tooth-11-speed-p13615. But I didn't pay that much!
Posted : 13/01/2024 10:26 pm
Sram Apex come in 160mm. They are more 'gravel' than mtb but that's just a ring change.
https://www.sram.com/en/sram/models/fc-apx-1w-d1
Posted : 13/01/2024 11:21 pm
 5lab
Hope so 155mms
Otherwise if she's not too hard on a bike, some Chinese square taper jobs on Amazon or ali express
Posted : 14/01/2024 6:06 am
zerocool and zerocool reacted
Don't forget 5DEV too if you want something bling. I'm running their 155mm R-Spec on the big bike. They go all the way down to 145 now:
Posted : 14/01/2024 7:31 am
 MSP
I got some 150mm goldix cranks from aliexpress for my 5ft tall girlfriend. They are a 24mm spindle (HTII) and fit sram direct mount chainrings. They are a lot cheaper than the other options and quality is fine.
Posted : 14/01/2024 2:14 pm
Shimano XT comes in 160mm.
Posted : 14/01/2024 3:31 pm
XT is 165 not 160
Posted : 14/01/2024 10:20 pm
Unite cranks 155 to 175 in 5mm increments. Only DUB and 30mm axle thought.
https://uniteco.bike/shop/drivetrain/crankset/crankset/
Posted : 14/01/2024 10:27 pm
ProWheel do lots of different sizes and seem to be good quality based on the ones I've seen as OEM parts on bikes. But I've never found a supplier for them as an aftermarket part.
Worth looking at Frog bike spares too
Posted : 15/01/2024 11:45 am
Hi all I cannot post a new topic for some reason but I'm also interested in a shorter crank that fits a DUB BB.
Non DUB short cranks can be had as little as £70 with a lot of choice. For DUB it seems to be £200+ and for the same weight as SRAM DUB ones which are 10-15mm larger and less than half the price...
Do I just need to wait longer for more options to appear on the market..
Posted : 17/01/2024 10:41 am
